Running hot after jetting changes
1 reply to this topic
  • okieguy
Posted October 04, 2002 - 04:16 AM
I have gone to the following jetting;
35pj
50pas
emm-3
155mj
160maj
Running yz timing, air box lid removed, wb-e series pipe with 7 disk. Less than 1000'
Engine temp seems to be running hotter than before.
Does not seem to run lean other than the engine heat.
My question is: Has anyone else had any problems running hot on the leaner jetting settings?
Thanks...
  • Uncle_Rich
Posted October 04, 2002 - 01:52 PM
If it started running hotter after changing jets its probably running lean
Running lean melts pistons, rings and valves
Do a search on jetting you should find someone in your neighborhood and see what jets they are running
Rich
