front brakes still soft..
37 replies to this topic
  • 2001YZF426Rider
Posted November 28, 2007 - 07:24 PM
I just put a set of supermoto wheels on my 426.. I also installed a SS Galfer line, 320mm EBC disc, and relocator bracket.. I couldnt bleed the brakes, but finally i got them to work but they still are softer then i would think they should be, especially with that oversized disc..
I tried the normal, pump a few times, hold, crack screw, close screw, release lever, and repeat.. But it doesnt seem to be helping..
Posted November 28, 2007 - 08:25 PM
What works best for me is gravity bleeding. Take the reservoir cover off, be sure it's filled, and tickle the lever through just the first millimeter or so of travel to dislodge any bubbles that may be stuck directly under the fill port. Then, crack the bleeder and simply let the fluid run through the system, keeping the M/C filled as it goes. You should soon see a few bubbles pop out through the bleeder. Close it, tickle a couple more times, fill it as needed, and you should be done.
  • 642MX
Posted November 28, 2007 - 08:46 PM
I've never had luck bleeding the brakes on our bikes the old fashioned way. So I tried a vacuum bleeder and it took less than 1 minute to get all the air out.
Don't over-look the master cylinder itself. Earlier this year, my wife was complaining about her front brake not being strong enough. I tried bleeding it a few times and it still sucked. I ended up getting a rebuild kit for the master cylinder and the brake now works like new.
  • dmoney1074
Posted November 28, 2007 - 08:53 PM
I found that on the front brake especially, you have to do it like 1,000 times to get all the air out. A few tricks, bleed the hell out of them, then zip-ty the lever down to the grip and let it sit overnight. The next day, take off the zip-ty and as hard as you can flick the brake line with your finger starting from the top down. Then bleed like normal again. This has always worked for me.... Good luck!
  • todds924
Posted November 29, 2007 - 05:55 PM
Use a vacuum bleeder.
  • 2001YZF426Rider
Posted November 30, 2007 - 02:49 PM
Well i forgot to mention that i used a syringe and back bled the brakes, but doing it that way, when i force the fluid through the bleeder, should i crack the lever while im pushing the fluid in, or leave the lever alone?
I did this, and got pressure, but its not as good as it should be.
Posted November 30, 2007 - 03:33 PM
Leave the lever alone. In that position, the fluid has a direct path from the caliper to the M/C reservoir. If you pull the lever more than the first little bit, you close the reservoir off from the system.
  • stillsun
Posted November 30, 2007 - 11:27 PM
As stated above, a vacuum bleeder makes this a 60 second job.
J
  • stillsun
Posted December 01, 2007 - 07:14 AM
Here's the setup I use when doing them (although mine is Craftsman brand) it's the same exact setup.
http://www.harborfre...temnumber=92474
J
  • 2001YZF426Rider
Posted December 01, 2007 - 05:05 PM
That is where i went wrong! I cracked the lever about 3/4'' I will try it leaving the lever alone..
  • todds924
Posted December 01, 2007 - 07:27 PM
DOOOOOOOOOOHH!!:thumbsup:
  • Ice67
Posted December 01, 2007 - 10:32 PM
Stillsun, how much vacuum do you use? I was helping a friend, and even though we barely had the bleeder open, I thinlk we were getting air past the threads. Is this possible?
  • stillsun
Posted December 01, 2007 - 10:38 PM
Here's my procedure from memory so it may be missing some finer details:
1) Remove reservoir cap.
2) Place box wrench onto bleeder valve so that you can easily open close it.
3) Clamp rubber hose from vacuum onto bleeder valve with worm type clamp so you know for sure it's not sucking in air from the outside.
4) Build up some vacuum before opening the valve (it should hold since you've used the clamp)
5) Open the bleeder valve slowly, before your vacuum reaches zero close it back off.
6) Top reservoir off, start back at step 4 and repeat as necessary, usually twice gets it.
Hope this helps.
Josh
  • MTshirt
Posted December 02, 2007 - 05:53 AM
Are you using the stock brake lever?
I have not found an after market lever that has the solid low travel feel of the stock lever.
  • RCannon
Posted December 02, 2007 - 09:18 AM
What pads are you using??? I found ebc and galfer pads to feel really spongy even when the braking system was perfectly ok. This was especially true with either brands black colored pads vs a more metallic looking pad.
A switch to Honda CR front pads made them feel great.
  • dmoney1074
Posted December 02, 2007 - 11:44 AM
Hey thats new to me.... what cr pads will fit? Is this for a 426?
  • 642MX
Posted December 02, 2007 - 12:50 PM
Most all of the newer bikes use the same front brake pad.
  • dmoney1074
Posted December 02, 2007 - 01:19 PM
Do you remeber what you used? Also did you use OEM or aftermarket? Thanks!
  • 642MX
Posted December 02, 2007 - 01:21 PM
I personally use the $10 pads from Rocky Mountain. They are cheap and perform very well. :thumbsup:
  • blue9red9
Posted December 02, 2007 - 04:20 PM
Whenever I use the vacuum bleeder, I get air in the bleed line due to air coming down around the threads of the bleeder screw and back up the bleeder hole. I never know if it's all out of the brake system because there's always air in the bleeder hose line. Any advice? Do others see this also?
  • Hot  50 replies
  • 10 replies
  • Hot  113 replies
  • 0 replies
