5.3 or 5.6?
4 replies to this topic
  • MaxPower
Posted November 28, 2007 - 05:16 PM
[COLOR="Green"]Is the stock spring rate in the rear for a 04 WR450 5.3 or 5.6?I thought it was 5.6 but Im reading 5.3 in the manual
Maybe Im looking at it wrong
Thanks[/COLOR]
  • Bleeds_Blue
Posted November 29, 2007 - 04:47 PM
I believe it's a 5.3, that's what came on my 06 WR450. I now have a 5.6 and feels much better. I'm 6' & 195 pounds w/o gear. Hope this helps.
  • MaxPower
Posted November 30, 2007 - 02:03 AM
[COLOR="Green"]Thank You Sir
That was what I was looking for
[/COLOR]
  • fordman
Posted November 30, 2007 - 01:18 PM
sorry to hijack but does the 5.6 make the bike higher or does it just stiffen the sus.?
  • SXP
Posted November 30, 2007 - 01:30 PM
You can crank any rate spring down far enough (preload) with the adjusting collars to the point where the bike will not sag at all under it's own weight, i.e., it will sit higher. The correct rate spring for you weight with the right amount of preload/sag will cause the bike to have the same attitude as a lighter spring correctly setup for a lighter rider. Hope this helps.
