Oil oozing at clutch actuator 94 xr600
7 replies to this topic
  • tanstaafl26
Posted November 28, 2007 - 12:17 PM
HI all
My brother and i purchased 2 XR 600's last week. His is a 1994 model. After two rides we noticed that there's oil oozing out of the clutch actuator (?) where it enters the case cover. Is there a seal we can replace? Thanks for the help to a newb.
  • cleonard
Posted November 28, 2007 - 01:38 PM
Yes, there is.
  • bajajoaquin
Posted November 28, 2007 - 08:19 PM
Since I'm the brother in question, can I follow up on the reply? Is it just a seal issue, or am I likely to find it's a bigger issue like a bent shaft, or.....?
Thanks
  • Beerad
Posted November 29, 2007 - 08:28 AM
most likely it's just the seal as cleonard stated.
  • XR650L_Dave
Posted November 29, 2007 - 08:39 AM
Does it work?
Does it leak less than a drip?
---> don't mess with it!
My philosophy, anyway.
Dave
  • rangerman
Posted November 29, 2007 - 04:32 PM
Tampering with it could make it worse.
You guys are like me and my bro....we both ride 600's:thumbsup: :thumbsup: :busted:
  • bajajoaquin
Posted November 29, 2007 - 06:43 PM
That's my kind of advice: do nothing!
Well, I'll probably ignore it for another ride, to see if it gets any worse. Thanks.
  • exaresix
Posted November 29, 2007 - 07:01 PM
Take it to an authorized Honda dealer and have them fix it. If you do it yourself, you will have to pull the stator cover and reseal that gasket as well. If you do it and it still leaks (believe me it can), then you have to do it all over again until it is fixed. If you let them do it, then it is their responsibility.
Honda XR650L 2016
  • 0 reviews
  • Hot  60 replies
  • 9 replies
  • Hot  186 replies
