New to thumper talk,But a dirtrider.net member.Just wanna say whats up.
15 replies to this topic
  • yz400f_Torqer
Posted November 27, 2007 - 11:09 PM
Well im new to thumper talk and Im allready apart of dirtrider.net allready and they dont seem too wanna help me out with my yz400f.It has a edelbrock carburetor and I was just wondering if this a 4-wheller carb.Cause I cannot find them anywere for dirtbikes.Any sugestions?Oh yeah Im new to 4-strokes also.Just got the bike 2 days ago:applause: Ive had 2-strokes in the past.And moved up to 4-strokes.And my bike is really hard to start.The carb dosent have a choke???its a auto choke:excuseme:
  • FeliX 450
Posted November 27, 2007 - 11:20 PM
you will find your answer here
http://www.thumperta...isplay.php?f=21
post your question there and the almighty greyracer will help you out
  • yz400f_Torqer
Posted November 27, 2007 - 11:34 PM
thanks felix that is an awesome bike you have there.I love the white!I bet that one hauls balls!Any engine mods?
  • FeliX 450
Posted November 28, 2007 - 12:21 AM
thanks :thumbsup:
and nope she is stock, i'm thinking about hotcams and WB exhaust, but not now, suspension first :busted:
  • yz400f_Torqer
Posted November 28, 2007 - 12:28 AM
Very nice!!!
  • Ga426owner
Posted November 28, 2007 - 12:55 PM
NCMountainman has a ton of experience with these Edelbrock carbs - you should pm him.....:thumbsup:
OH and welcome to TT
  • yz400f_Torqer
Posted November 30, 2007 - 05:57 AM
Ok guys I tryed to start it when it was cold!And second start it came too life.I had to prime the accelerator pump with 4 twists of the throttle and she started right up!!!Well its still popping and backfiring a little bit,accel and decel.So do you think I should run it a little richer.(maybe 1 clockwise click) too start out with,then move from there?I will change the oil and filter later today.thanks for all the info guys!You all are AWESOME!
Posted November 30, 2007 - 07:26 AM
SOME Decel popping is normal, and it's harmless. That would be where it pops up to 3-4 times while decelerating in gear. If it pops more than once in a while when you just rev it up at a standstill, the idle mixture is probably lean, or you have an air leak in the exhaust.
Erratic, irregular popping out the exhaust while holding a steady speed or accelerating is quite often due to the main circuit being lean. Yo might try going one step richer at a time to see what happens.
Download a manual from Here:
http://www.yamahaown...ook.com.au/?r=0
If you have trouble with the file, and you might, then use a manual for a 2000 YZ426 from this site:
http://www.yamaha-mo...ice/manuals.jsp
Study the oil change procedure and understand it first, then do the job. Skip the part about removing the oil line and the filter screen in the frame. Key points:
>Run the engine for a minute first
>Drain the frame and retighten the drain plug (hold a pan up close to the drain hole!)
> Drain the crankcase and retighten the drain plug
> Change the filter
....Don't loose any of the 4 O-ring seals from under the cover
....Don't strip the bolts, especially the lower one
....Tighten them evenly so you don't break the cover
> Refill with 1.4 Qts, run the engine for a minute, shut it off, check the level and add to the correct level.
  • yz400f_Torqer
Posted November 30, 2007 - 08:41 AM
Well it pops alot when I first start it when reving in neutral.But havent really got to ride the bike at all.Just down the street.And is draining the frame and the crankcase the same thing/same bolt?I will read the links you posted ASAP!thanks......
Posted November 30, 2007 - 01:14 PM
...is draining the frame and the crankcase the same thing/same bolt?
No. If you can't get one of the manuals for some reason, try this link. Use the procedure for the '01/'02 models shown, again leaving out the part about the frame screen and the oil line.
http://www.thumperfa.../oil_change.htm
  • SUnruh
Posted November 30, 2007 - 01:15 PM
um, no!
you really need to read the manual.
  • yz400f_Torqer
Posted November 30, 2007 - 04:13 PM
Thanks alot grey.The other downloads would'nt work my comp did'nt wanna download it.But this one works fine.But I rode the bike today for like 4 hours,and that bike makes my cr125 look like a pit bike!The power is INSANE!I never even use 5th(I ride tight trails) I get it up to 3rd and its fast enough.But everytime I decel it pops like 30 times in any gear???Its super loud!!It pops real bad.......When I rev it up in neutral it pops on accel a little bit but not that bad.But really pops on decel.is it running real lean or does the exhaust maybe have a leak?Or the boot(s)connecting the carb?thanks and Im planning on riding tomarrow so need help right away......
Posted November 30, 2007 - 04:22 PM
The first thing is to check the exhaust system for leaks. Once you're satisfied it's OK try getting the idle mixture a little richer.
  • yz400f_Torqer
Posted November 30, 2007 - 04:26 PM
how do I check the exhaust for leaks?Do I just start it and feel around for leaks?I think for sure it has a exh leak on the silencer.On the end that has the rivits on the end.the rivits are popped out....And it dosent look like its sealed all that good.could that cause it?And to richen it you turn it clockwise right?thanks GREY...........
Posted November 30, 2007 - 09:42 PM
A leak at that point won't usually cause it to pop much. To locate leaks, have someone work the throttle while you listen close up to the mid pipe and header/head joints by holding a 2 foot hose to your ear. You'll know if you find one.
Don't know on the Edelbrock.
  • yz400f_Torqer
Posted November 30, 2007 - 09:53 PM
oh so should I just turn it in clockwise for it to be a little richer?I hate it popping like that!
  • 0 replies
  • 5 replies
  • Hot  47 replies
