XR650R Fork oil change
7 replies to this topic
  • bongodave
Posted November 27, 2007 - 01:39 PM
I'm new to my BRP, and I don't have the owner's manual. Looked, but didn't find a how-to. On previous bikes there was a drain hole. Do I just take out the bottom adjuster? :thumbsup:
  • porterdog
Posted November 27, 2007 - 03:29 PM
Nope.
Easiest way is to take the forks out of the trees, remove the top caps (watch out- they're loaded from below by the spring) and pour/pump the old oil out.
  • Krannie McKranface
Posted November 27, 2007 - 03:34 PM
....and when you turn them upside down, you will want to pump them a bit, so beware of oil spurt.
Don't take out the bottom adjuster.................
Also, put in a tiny bit less oil volume than the manual suggests (20 vs 21.5oz). This will make it plusher.
  • HOTDAMN
Posted November 27, 2007 - 06:56 PM
I know that ass from somewhere :thumbsup:
What fluid are you planning on using?
  • bongodave
Posted November 27, 2007 - 06:59 PM
Thanks, guys. Figured that might be the way. So be it!:thumbsup:
  • bongodave
Posted November 27, 2007 - 07:03 PM
I know the Deadhead symbol! The Hoosier with the new '07!
I'm putting Honda 5 wt., though I'm told some guys use 2.5. I'll probably use a little less, as suggested here, and see what I think.
My 2000 is a battered pos, but a few thousand dollars later, it's shaping up.
What can I say? I LIKE THAT ASS! It's creamy...
  • hill5150
Posted November 27, 2007 - 08:02 PM
That's one fine ass there........
  • GlobalWarmer
Posted November 27, 2007 - 09:16 PM
You should measure the oil height not the amount poured in. When you just drain the forks you don't always get it all. I believe the standard is 4.7 inches from the top of the tube with the sliders all the way down and the spring and rebound rod removed. Plus you know where you're at if you want to add or remove oil.
Washington
  • Hot  32 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
  • Hot  186 replies
Honda XR650L 2017
  • 0 reviews
