Lowering a WR450...Pro's and Con's?
9 replies to this topic
  • cpr1
Posted November 27, 2007 - 07:49 AM
I just recently picked up a 04 WR450 with an already installed lowering link in the rear(1.5 inches lower).
While I do think that it's great for my shorter leggs, I also think that my handling is a bit off. It doesn't seem to turn as well as I thought it would, so I slid the forks up to the second line and that seemed to help a bit.
Anybody have similar experience with a lowering link on their WR?
Thanks in advance.
  • tweav
Posted November 27, 2007 - 03:37 PM
Yes I lowered my 07 and ,it does not turn as well as it did ,but it feels better at high speed , a little more stable, less of a rut catcher .but does not cut a turn as well. fair trade I think
  • CRF250X Rider
Posted November 27, 2007 - 03:45 PM
You loose 1.5 inches of travel.
  • tweav
Posted November 27, 2007 - 04:56 PM
Are you sure you lose travel? the shock's range of motion has not changed the only thing I changed was the starting point of the swing arm . not the length of the shock . I know I lost ground clearance . but my wr450 is not my all out race bike . it is my trail hopper dual sport . so for what it is for it suits the task . I'm not going to lower the other bike .
  • Just_a_trail_rider
Posted November 27, 2007 - 05:27 PM
Thanks in advance.
I have an 05 that I had professionally lowered (no lowering link)
I definitely needed it since I like to ride the technical stuff and my legs aren't super long.
Handling on the bike is not that great if it isn't properly sprung and the clickers adjusted correctly. I think the lowering link makes it more difficult to dial in properly.
My 05 doesn't turn all that well and it has nothing to do with the fact that I lowered it a bit. Sliding the forks up is a good thing to do.
  • WR_Dave
Posted November 27, 2007 - 06:27 PM
Lowering links only lower the rear of the bike and give it that "waay coool chopper style" that makes it turn really nicely in a 10 acre lot, but not in the tight single track. If the bike needs to be lowered have it done correctly by a suspension shop. That way you can keep the balance of the bike and still reach the ground. My .02 --:thumbsup: WR Dave.
  • cpr1
Posted November 28, 2007 - 05:33 AM
Thank you for all of your insight...:thumbsup: I greatly appreciate it.
  • specialk6r
Posted November 28, 2007 - 12:21 PM
It's turning slower because by dropping the rear you increased the rake (a-la west coast choppers.) I know that everyone says to have a suspension shop do it right by installing shorter springs, but for a trail cruiser couldn't you just drop the fork in the triple clamps the same amount as you lowered the rear? Seems like that would maintain stock geometry. What am I overlooking?
Posted November 28, 2007 - 12:38 PM
The forks aren't verticle, so don't think that sliding them up 1 1/2 inches reduces the front height by the same. You need to figure that out.
Also, with your springs compressed more in the rear, I tend to think that the rear end will wallow a bit. You'll notice that when the turn isn't as smooth as asphalt.
  • Gandalf_WR450
Posted November 28, 2007 - 01:11 PM
I am in same situation- I installed a lowering link after racking myself up with several falls at a dead stop (I am 6') and I now am going to make an educated guess on raising the tubes in the clamps. I did not note height change in rear, so I do not know what change occured. I ride tight trail not MX- '03 WR450- any help at a guess of how much to raise the forks in the clamp? I was going to go 1/4" for the first try.
I know conventional wisdom is set it up proffessionally, but I paid $1800 for the bike- due to my location it would be $1000 to have it done right- for my riding style I just want to get it closer to level. Any suggestions would be appreciated.
