xr 600r biatch to start and no idle
8 replies to this topic
  • banshee power
Posted November 26, 2007 - 03:06 PM
I am having a problem...if it is a problem.
I can't seem to get it started. It takes me forever.
only Starts on the 20 kick cold and when it does can´t idle, goes off.:busted:
this hapens after i have cleaneded the bike under the seat with water and set the valves to factory specs.
What do you recommend doing to get it started ?
and fix the idle problem?:thumbsup:
Thanks
  • Owyhee
Posted November 26, 2007 - 03:10 PM
Thanks
Try turning up the idle screw a bit before starting.
Also, some older 600s have a weak coil that can cause hard starting.
"O"
  • martinfan30
Posted November 26, 2007 - 03:12 PM
check the stator.
  • BOLT Performance
Posted November 26, 2007 - 03:14 PM
Replace your clogged pilot jet before you start tearing the bike apart.
  • creeky
Posted November 26, 2007 - 04:32 PM
Cold Start:
1. turn idle screw up
2. choke full on
3. open throttle & hold
4. kick through 3-4 times
5. close throttle & leave it closed
6. bring the piston up on compression stroke, push kickstarter 2-3 more
inches.
7. bring kickstarter back up to top and KICK it.
8. move choke lever to 1/2 off, turn off choke after 2-3 minute warm-up.
Hot start:
1. pull in comp release, open throttle and kick through 3-4 times
2. close throttle and kick it the same as if you are cold starting
Once you get the hang of it, you will most likely modify the procedure to your own liking, then it will be 2nd nature.
  • Boater
Posted November 26, 2007 - 05:29 PM
Cold Start:
2. choke full on
inches.
Hot start:
You sound like you may have done that once or twice!! :thumbsup:
  • cleonard
Posted November 26, 2007 - 11:25 PM
There are three keys to an easy starting 600. The first is a 68 pilot and the second is a stator that works. The third is to be in neutral.
Mine usually starts first or second kick cold or hot. I do not even have a choke in my bike. I had to remove it as it was about to beak off and get sucked in. If it is really cold I lay the bike down to flood (prime) it.
I'm a big boy and I kick it really hard. That helps a lot.
  • zipper600
Posted November 27, 2007 - 11:39 AM
i have 59 kilos and start it on 2nd kick:p
  • banshee power
Posted November 27, 2007 - 02:58 PM
tank´s guys for your help.
  • Hot  35 replies
  • Hot  29 replies
Washington
  • Hot  32 replies
  • 4 replies
  • 3 replies
