Backfire screen - keep or remove?
4 replies to this topic
  • jd01
Posted November 26, 2007 - 11:30 AM
I have an 05-WR450 and a 06 WR250 that I am working on the mods for. I am trying to determine exactly what airbox mods to to. As a minimum I will pull out the snorkel (opening up the extra space in between tubes). But that backfire screen seems awfully restrictive. It can't be more than 70% open. It seems like all the other mods are a mute point unless that screen is removed. Anybody have any performance data on the air filters with the fire retardant material? I have read that some feel the new air filter is actually more restrictive than the fire screen. Thoughts?
Thanks,
  • SXP
Posted November 26, 2007 - 12:59 PM
Thanks,
Tests have shown that the filter (even a good after market filter) restricts airflow more than the backfire screen. Therefore, you would be gaining nothing by cutting out the screen.
  • GENE426
Posted November 26, 2007 - 01:03 PM
I thought about it and decided not to take a chance of my bike burning up
  • JVP
Posted November 26, 2007 - 07:12 PM
Not a good idea removing the screen. You are not gaining much in performance, but you gain far more risk. One good backfire could ruin your whole day.
  • dominator426
Posted November 27, 2007 - 06:22 PM
Cutting out the screen on my 2002 426 made a significant difference. I actually had to switch to a thinner/richer needle to make it work. I've never had a backfire or any concerns with a UNI air filter and Maxima's synthetic Fab 1 filter oil...
By the way, I was also able to improve air flow by matching the carb to engine rubber flange inner bore, which closes in when tightened, as well as remove flaws and ridges at the airbox flange, etc.
