Grenaded rear hub
12 replies to this topic
  • miguelitro
Posted November 24, 2007 - 09:26 AM
bearing went south fast and this happened either when it went or on the ride out. The rim was warbling a little but:D
any one have any leads on a replacement hub?
Mike
  • Potts228
Posted November 24, 2007 - 05:10 PM
I've got a hub for sale... $100.00 plus freight.
potts.d@sbcglobal.net
  • miguelitro
Posted November 25, 2007 - 10:56 AM
where are you in CA?
thanks
Mike
  • Potts228
Posted November 25, 2007 - 04:52 PM
thanks
Mike
Burbank, CA 91501
  • miguelitro
Posted November 26, 2007 - 04:39 PM
I will let you knwo very shortly if i cannot find one locally
Thanks
Mike
  • Docmarkw
Posted November 28, 2007 - 08:56 PM
Yea, been there done that. When I was looking for a hub there were none to be found (used). Ended up buying a new one off Service Honda.
  • drop
Posted November 29, 2007 - 10:35 AM
Jump on that deal from Potts228. Hubs are big bucks.
  • FoolishMortal
Posted November 29, 2007 - 05:35 PM
For real. A new one from Service is $240. :thumbsup:
  • quicksilver
Posted November 30, 2007 - 06:47 AM
What's the cause? Does this happen out of the blue? Is there any method to minimize it occurrence?
  • drop
Posted November 30, 2007 - 02:05 PM
I broke one on an xr250r. I think I had the chain adjusted too tight. I was jumping, and bottomed the rear suspension, and the rear hub cracked just like that. Rookie mistake. Costly one at that.
  • keith41
Posted December 01, 2007 - 11:38 AM
I just did the same thing but i blew out the sprocket side
  • miguelitro
Posted December 03, 2007 - 08:58 AM
that was not my issue.:thumbsup:
I think i found a fix for this but its not the cheapest. Trading this bike in as is for an 07. This scooter has seen better days, luckily it sure has seen a lot of better days, checker flags, mexican taco stands. I am washing my hands of her
  • Docmarkw
Posted December 03, 2007 - 11:26 AM
I don't know the resons for hub failure with the others, but I know why mine went bad. Lack of maintenance, I thought I was maintaining the bike well with oil changes and other stuff, but I never looked at the bearings. The bearing cage broke down and released all the bearings inside the hub. One or more of the bearings some how moved up between the hub and the spacer and one of the bearings finally blew through. Expensive lesson to be learned here.
  • Hot  29 replies
  • 4 replies
  • Hot  35 replies
  • 9 replies
  • 17 replies
