my pig won´t start
5 replies to this topic
  • banshee power
Posted November 24, 2007 - 06:31 AM
hi people.
My bike won't start.
the carburettor is ok.
but i think the problem is electrical.
after i kickstarted lots of times she tries to start,but without sucess.
all she does is backfire and nothing.
i don´t now were to start looking for the problem.
could it the cdi or the ignition coil?
many thank´s from portugal.
  • philipstjohn
Posted November 24, 2007 - 07:19 AM
hi people.
A few more clues and we might be able to help you. What bike and year, when was the last time you had her fired up, have you checked for spark?
:thumbsup:
  • Jon-D
Posted November 24, 2007 - 07:20 AM
for electrical, you cannot check the CDI, only eliminate everything else first. get a hold of a manual and ohm out the coil, stator, trigger, spark plug wire and compare the results to the tolerances. if you don’t have a manual, try a search on this form; people may have already posed electrical tolerances from their own troubleshooting experiences. also consider changing out your spark plug if you have not done so already (eliminate that item), and lastly, check your valve clearances. out of spec valves makes starting difficult.
Hope this helps.
  • Krannie McKranface
Posted November 24, 2007 - 12:22 PM
Wait, back up: How do you know it''s not the carb?
The most common starting issue for XR/L's is old gas and/or a clogged piliot jet.
  • banshee power
Posted November 24, 2007 - 02:13 PM
hi guys.
the problem is this: the bike was runing great, but i was lubing the wiring and accidentally switch the green and yelow wire that cames from the strator.
and after that my pig won´t start.
my bike is a honda xr 600r duall sport from 1995 and comes without battery only strator (europe version).
what should i look for to solve the problem.
any help please.
best regards.
  • banshee power
Posted November 24, 2007 - 02:26 PM
ops. i was just forgeting that i adjust the cylinder head valves to and it ran fine. so i don´t now if the problem is from the valves or electrical.
tank´s
  • 17 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  35 replies
Washington
  • Hot  32 replies
Honda XR650L 2017
  • 0 reviews
