"03 Yz450
12 replies to this topic
  • Throwingdirt
Posted November 23, 2007 - 12:21 PM
Does anyone know the the recommended gearing on a YZ450 to go a little faster? I had a 48t sprocket when I bought it, put on a 51t sprocket and seems to be going a little slower.:thumbsup:
  • IHScoutII
Posted November 23, 2007 - 12:42 PM
To go faster, put a bigger sprocket on the front and/or smaller on the rear.
  • sprint4425
Posted November 23, 2007 - 02:15 PM
you might be going slower but i bet your bike pulls wheelies a little easier.
  • Ga426owner
Posted November 24, 2007 - 01:26 PM
I found that a 47tooth rear is the ticket for the 03. Being a 4speed this sprocket allows you all the top you can handle and gear spacing/shifting is much better:thumbsup:
  • John407
Posted November 24, 2007 - 01:42 PM
I agree a 47 rear is great on this bike.
  • Vinny2692
Posted November 24, 2007 - 02:50 PM
just another question. I have a 45 tooth on my 03 right now, but its not great for mx. I was thinking a 48 tooth, maybe a 51? Which would be best, i want as much low end as possible.
  • GENE426
Posted November 24, 2007 - 02:57 PM
What kind of track do ya ride one
Lots of tight turns and hills or more open and faster speed type?
i run a 48 on my 04 YZ450 and it seems good
  • Ga426owner
Posted November 25, 2007 - 09:32 AM
45 is too small for mx....I like the 47 for longer higher speed tracks and would go up no more than a 49 ever.....over 49 way way too much shifting
  • Vinny2692
Posted November 25, 2007 - 12:05 PM
i ride alot of tight tracks where i seem to have trouble making enough speed to clear some jumps, so i was thinking maybe the bigger sprocket, like the 51 tooth would be better.
  • tnl
Posted November 25, 2007 - 12:29 PM
Stock on mine was 14/51 and I changed it to a 14/48 and gained about 12 mph in top gear if that's what you want? Of coarse your gonna go faster in 1st gear too?
Posted November 25, 2007 - 04:38 PM
Remember that yours is an '05, and has higher primary gearing. An '05 with the stock 14/51, and an '03/'04 with the stock 14/48 are within 1% of being geared exactly the same.
Throwingdirt,
What year is the bike?
  • Throwingdirt
Posted November 26, 2007 - 06:30 PM
I have a 51 on my '03 right now, but you top out to quick. (But you do pull wheelies like crazy.)
Posted November 26, 2007 - 07:11 PM
Then a 48 rear will return you to stock gearing.
