throttle cable
3 replies to this topic
  • JT1
Posted March 29, 2002 - 08:00 AM
I was riding in the Mojave last weekend with a friend. Hr rides a YZ400. When we returned from a ride we noticed his return throttle cable was broken / sheared in half (approx 1" from the carb). Has anyone else experienced this?
  • Chris_C
Posted March 29, 2002 - 09:28 AM
JT,
I believe this is a common problem. It can be corrected by properly adjusting the cables at the carb in order to align the cables with the pulley. On my bike, I had to bend the brackets that held the cable adjusters. You might want to remove or loosen and rotate the carb to check this alignment. Hope this helps.
Chris
  • YAMAKAZE
Posted March 29, 2002 - 12:37 PM
Terry Cable also make a trick throttle wheel that prevents fraying and keeps it in alignment.
Bonzai :)
  • GPS Dual Sport
Posted March 29, 2002 - 02:48 PM
It's very common. My 98 WR has just finished munching on it's second cable. At the current rate of consumption it will need a third cable after 10,300 miles on the odometer.
I have heard that Yoshimura also makes the throttle wheel for the FCR carb on the DRZ. Which is the same carb on the WR/YZ.
