Ti valves for yz426
2 replies to this topic
  • addicted_No1
Posted November 20, 2007 - 02:21 AM
What is the best valves for a yz426 and where do i buy them?
Regards Emil
Posted November 20, 2007 - 07:40 AM
In my opinion, the best Ti valve to use in a YZ426 is the stock replacement part. Nothing I know of really lasts any longer when the head is prepped correctly.
Xcelite valves are said to be very good, also, but I have only the manufacturer's claims to go by. They are also very expensive.
If you are looking for a low cost solution to rebuilding a 426, you can substitute the stainless steel valves from a 2000 model YZ426. These last even longer than the stock Ti valves, and cost about a third as much or less. Be sure to use the valve springs from the 2000 as well, as the SS valve is heavier.
  • 642MX
Posted November 20, 2007 - 04:31 PM
Should you choose to get the SS valves, make sure you replace the keepers and cotters too. :thumbsup:
