1987 XR600 owners, help!
12 replies to this topic
  • Owyhee
Posted November 19, 2007 - 08:47 PM
I purchased a WP shock off a fellow TTer from a semi-custom 1993 XR600 for my 1999 XR600. The shock is pretty trick but doesn't fit my 1999.
Problems: The upper mount is different. My stock 1999 shock has a thin upper mount with a pressed-in ball. The WP shock has a thick upper mount with two pressed-in spacers. The upper mount is about 1/8" too wide to fit in the frame. The lower mount needs a bolt with a nut while the stocker's bolt threads into the lower shoock mount. The nut on the WP shock slightly contacts the swingarm at maximum depression.
1987 XR600 owners: The donor bike has a horizontal reservoir tray mounted on the frame just like a 1987 XR600. Are the upper and lower shock mounts the same as the WP shock or the 1999 shock? I need to know because the shock has no stock number and I'm looking for a rebuild kit.
Thanks in advance.
"O"
  • rangerman
Posted November 19, 2007 - 10:42 PM
Not quite sure....but do you want a pic of my stock 87 xr600 around the shock area? Thanks
  • Owyhee
Posted November 20, 2007 - 06:32 AM
Yes! That would solve the problem perfectly.
"O"
  • rangerman
Posted November 29, 2007 - 12:08 PM
Oops, forgot about this thread. Anyway, here ya go, I hope it still helps!!!
  • Owyhee
Posted November 29, 2007 - 10:22 PM
Thanks!
  • rangerman
Posted November 29, 2007 - 10:54 PM
No problem. What is the thing in the air box for? (2nd pic down)
Thanks
  • Owyhee
Posted November 30, 2007 - 06:38 AM
Thanks
I can't see pics at work, but if I remember correctly there was an electrical thing hanging down?
"O"
  • rangerman
Posted November 30, 2007 - 09:10 AM
Yes, it was.
  • Owyhee
Posted November 30, 2007 - 04:38 PM
I'm not a genius at electrical stuff, but it looks a bit like a capacitor for a dual-sport kit. Is there writing on it?
"O"
  • rangerman
Posted November 30, 2007 - 04:43 PM
Yeah, it is connected to something. I left it alone. I will get another shot of it. Thanks
  • rangerman
Posted November 30, 2007 - 05:20 PM
I think it says resistor or something like that on it.
Here's my bent bars and my speedo!!!:thumbsup:
I found another problem. I think this will shift my hard shifting problem. I hit neutral so many times. It is my shift lever is against the side.
Where do you find a rear light cover?
Sorry about the dirty bike. I would clean it but it is like 40 degrees out and probably raining.
  • maxbowersox
Posted March 04, 2009 - 01:44 PM
nice bike, thanks for the pics. Yours is an 87 right? I am trying to put a 600 swing arm on my xr 200. Im looking for years that had aluminum SA, and drum brakes. I was told 86-87 were the only years. but I dont want to buy one till I know it fits. If you get a chance( and dont mind doing it) Would you mind measuring the with at the pivot bolt, and the length from the pivot bolt to the axel. It would help me tremendously. I have asked people on Fleabay for measurements of ones they are selling and get no response. Thank you. If you dont want to I understand.
  • Owyhee
Posted March 04, 2009 - 06:33 PM
PM TT member Yogi Bear. He has a 600 swingarm on his XR200. I think he has a thread on the swap too.
XR600 were drum brake through 1990.
"O"
