04-05 yz450f difference?
13 replies to this topic
  • blaster007
Posted November 19, 2007 - 11:44 AM
Does anyone know if and what the difference between these 2 years are?
I've seen that most parts fit from 03-05 but some only show for -05 only,and other's 03-04.I know 06 went to the aluminum frame and different motor.
  • KJ790
Posted November 19, 2007 - 11:47 AM
The biggest difference between 04 and 05 was the suspension. Other than that there were some small changes, but most parts will fit either year.
Posted November 19, 2007 - 12:05 PM
The '05 had the first twin chamber KYB fork (the AOSS, Air Oil Separate System) that was then also used on the '06 RMZ's and KXF's. It's a major improvement over the 48mm single chamber fork on the '04, but still not as good as the '06 and later SSS fork, by any stretch. They can be worked into a very nice fork though.
The other big thing was a general softening of the engine's power delivery compared with the '03-'04 models. I've never been on one, so I can't say first hand, but opinions of this run the gamut. Some say the bike is a power house with good top end, and others claim that they had a YZ250F with more snap off the bottom.
If you get a chance to ride them both, that should tell you.
  • TX-SANDMAN
Posted November 19, 2007 - 12:19 PM
Let me tell you about my 04 - it runs top to bottom with mucho grunto. Low end??? Will tall 15 - 44 gearing road race gearing I can pull the front end up in third at 10mph and run it to 75 in forth - even in the sand. It snaps of the bottom much more than my friends 06. Mine is still all stock and I love it - the forks are not as nice as the 05 and up though.
Posted November 19, 2007 - 12:53 PM
The brutal low speed hit of an '03/4 YZ450 is a lot like a late sixties muscle car; touch the throttle, break the tires loose. But from experience as the owner of both I can tell you that all that "snap" is much more thrilling than useful. The '06 (which is not really the issue here) will run side by side with my '03 up to 3rd gear, and then pull away. It's entirely likely that some people will turn faster laps on an '05 because of the more manageable power.
  • GENE426
Posted November 19, 2007 - 12:58 PM
perfect answers
  • mikedabike
Posted November 19, 2007 - 08:44 PM
I have a 03/04/05 and an 07 in the garage right now. I cant think of 1 part on the 04/05 that are not interchangeable. Even the parts with different part #'s are generally interchangeable. Internal engine and suspension parts excluded.
Posted November 19, 2007 - 10:30 PM
Every part of the engine that I'm aware of is interchangeable between '03-'05. Some are different, updated, or modified, but interchangeable, nevertheless.
  • blaster007
Posted November 20, 2007 - 02:01 AM
WoW,Thanks guys! All the info and feed back is awsome,I learned alot of different things about the same bike that i had no clue of.
The main reason for my queston's were in regards to aftermarket exaust,The exaust I was looling at was listed only for the 05 yz450f but i was sure all 3 model years were somewhat the same.
  • KJ790
Posted November 20, 2007 - 04:26 AM
Yes, the exhaust is the same from 03-05.
  • Ga426owner
Posted November 20, 2007 - 07:40 AM
What no 06.......to add to that collection? :thumbsup:
Posted November 20, 2007 - 07:52 AM
You should have said so.
Like he said, they're all 3 identical.
Posted November 20, 2007 - 07:55 AM
I think he needs to buy an '08, an '06, fill in the collection from '98 to '01, and then get one of each of the 3 limited or special editions, don't you?
  • Ga426owner
Posted November 20, 2007 - 08:07 AM
:thumbsup: :ride: :busted:
  • 0 reviews
  • 0 replies
  • Hot  36 replies
