How often do you change your oil?
57 replies to this topic
  • rangerman
Posted November 17, 2007 - 04:39 PM
Just wondering. I only go riding about 5 times a year, so I usually change it once or twice...what about you guys?
  • zipper600
Posted November 17, 2007 - 05:05 PM
1000 kms.road use only.
  • Krannie McKranface
Posted November 17, 2007 - 05:56 PM
-450x: every 100-ish miles maximum, or every ride if very dusty.
- XR650R: every 300 miles, or more if very dusty.
  • weskc35k
Posted November 17, 2007 - 06:25 PM
Every now and then.
  • Rman of 237
Posted November 17, 2007 - 08:13 PM
Every 6 to 8 hundred miles. I know the Hondas and the TW will go farther but Rotella is cheap:thumbsup: and I'd rather be safe than sorry.:thumbsup:
  • martinfan30
Posted November 17, 2007 - 10:11 PM
oil sucks...
every 1000 miles, with filter and screen cleanings.
  • absynth01
Posted November 17, 2007 - 10:56 PM
Every 2 rides. :thumbsup: Rotella. Filter and screen twice yearly, unless oil shows problems.
  • XR4DEZ
Posted November 18, 2007 - 04:10 PM
Are your rides a 1000 miles a pop, if so you might want to change it a few more times. :thumbsup:
  • absynth01
Posted November 18, 2007 - 04:42 PM
Typical 200+ sometimes 600MI. Oil is cheap, and these air cooled bikes run HOT!!!!
  • philipstjohn
Posted November 18, 2007 - 06:40 PM
Number one rule- follow the manufacture's schedule in your manual. :ride: :thumbsup:
  • martinfan30
Posted November 18, 2007 - 07:19 PM
better yet, change oil and filter every 1k to 1.5 k miles. never have a prob. this way, lubrication wise!:thumbsup:
  • rangerman
My manual was lost 20 years ago....now what do I do?
  • XR4DEZ
Posted November 18, 2007 - 07:21 PM
Every 300 miles for me.
  • martinfan30
Posted November 18, 2007 - 07:23 PM
follow the 1500 mile LOF routine with cleaning the downtube screen and clean the screen in the right side case every 3-4 LOF's. be good to go.
also stay away from "energy conserving" oils as a thread here recently stated.
  • AtomicGeo
Posted November 18, 2007 - 07:33 PM
Every 1K miles for me (incl. filter change)
:thumbsup:
  • Big Red Paul
Posted November 18, 2007 - 11:04 PM
I change oil every 1k, and filter every 2k.
What do you guys mean by screen cleanings? Where might I find these screens to clean ?
  • rangerman
Posted November 18, 2007 - 11:37 PM
Why should I stay away from energy conserving oils? I am using a Honda synthetic motorcycle oil right now at like $12 a pop.
  • Rman of 237
Posted November 18, 2007 - 11:58 PM
On the very bottom of the frame downtube reservoir right under the drain you'll see a fitting. Loosen the fitting and you'll see the the screen. Mines always spotless but what can I say about yours.:thumbsup: IMHO I think its the most usefull during break in as the filter should catch everything long before it gets to the screen but I check it anyway.:ride:
  • Big Red Paul
Posted November 19, 2007 - 04:15 AM
On the very bottom of the frame downtube reservoir right under the drain you'll see a fitting. Loosen the fitting and you'll see the the screen. Mines always spotless but what can I say about yours. IMHO I think its the most usefull during break in as the filter should catch everything long before it gets to the screen but I check it anyway.
Many thanks sir. Will check the screen next oil change.
  • absynth01
Posted November 19, 2007 - 05:43 AM
Good advice if you are running a stock bike the way it was supposed to be ridden. I'm far away from stock, and ride like a jerk. I don't run synthetic in my dirt machines, because you don't really get the properties of synthetic oils unless you don't change your oil frequently:thumbsup:. I do use Synthetic grease for ALL my machines including my vehicles, and marine toys. I don't even use synthetic in my boat , as you have to change it yearly used or not!
Another argument is the fact most of us are using wet clutches. Go ride a track or tight woods on a hot dusty day and see what your oil looks like. Slipping that clutch contaminates the oil and starts to clog the screens and filter. I prefer to be safe than sorry.
Working in heavy industry I run across this problem frequently. Ingersoll requires you to use their lable oil to keep your warranty. At 6000$ an oil change I sent the oil to the lab. Guess what, I can get the same oil (different manufacturer) for 1500$ an oil change. Once the warrantys are over I wonder what OIL I will use??
I work in the automotive industry, and know first hand how it works. Service parts and work is the big three's most profitable game.
  • 4 replies
  • Hot  35 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  60 replies
  • Hot  186 replies
