Changing Sprockets
5 replies to this topic
  • jamesinzinna
Posted November 16, 2007 - 01:49 PM
Could some of you verify and help me determine which sprocket sizes would make my 2000 650R go faster on the highways (lowering rpm's):thumbsup: Stock is 14-48 and my local dealer rep said more teeth while my friend and other on line seem to be reducing teeth? I purchased another stock 14 for the front as well as a 15. I am under the impression that one tooth in front is equivelent to four in the back. Anyway, I would like to go faster without reaming the motor on the expressways. Thanks for the feedback. :ride:
  • brp2004
Posted November 16, 2007 - 01:51 PM
More teeth in front, fewer teeth in back. Try 15/45 if you are doing mostly road riding. For exclusive road or freeway you will want to go even fewer teeth in the back.
  • gearloos
Posted November 16, 2007 - 02:00 PM
yup...smaller sprocket in the back = lower rpm
bigger sprocket in the front = lower rpm
  • cleonard
Posted November 16, 2007 - 02:22 PM
It is closer to 1 on the front equals 3 on the rear. The big difference between the two is that it is a whole lot easier to change the front sprocket. Since you already have the 15, try it. If you want more then change the back to a 45. I would not go below 45 on the rear if you still plan on riding in the dirt. When you are going for a dirt ride, swap the 14 front back on. It only takes a few minutes to do.
  • FoolishMortal
Posted November 16, 2007 - 05:08 PM
What he said. :thumbsup:
  • absynth01
Posted November 16, 2007 - 07:13 PM
Told ya! 14-45 is my choice. I'm bigger than ya but know you want to fly bye me. It will happen on my L for now, but the CR is in the basement now for a rebuild. Buy a T-CAT and shut up. Think of the DS roads on crotch rockets--thats snowmobile.:thumbsup:
  • 3 replies
  • 9 replies
  • Hot  186 replies
  • Hot  35 replies
  • 17 replies
