sator rewind question... how to solder??
4 replies to this topic
  • black in RI
Posted November 15, 2007 - 06:44 PM
so I wrapped the stator with copper wire..
i now have to solder the wires to the wires preexisting that ran to the bike that i earlier had snipped/
How do i solder exactly?
Do i need a soldering iron?? oI'm assuming I can't use my acetylene torch
now when i solder the copper wire to the other copper , is it simply wire to wire with solder connecting them? or is ther some other 'attachment i use?? some wire crimp type deal?
  • Krannie McKranface
Posted November 15, 2007 - 08:52 PM
Yes, you need a soldering gun, or a sodering torch. You need to practice soldering for a while before starting. Soldering is done by heating the metals to the minimum temp needed to melt the solder, while applying heat to wires and solder at the same time. Not too much heat. Apply heat till solder melts well, and remove immediately. A good solder is shiny. A bad one (cold) is dull.
Here is what I have done:
You must strip off the lacquer insulation from the copper wire. Dont burn it off, you must scrape/grind it clean. A dremel is good for this. Attach the wires together with a very tight connection before soldering. EG: a very tight small open loop at the end of each wire, hook them together, and crimp shut, then solder. Use shinkwrap over the soldered joint.
  • black in RI
Posted November 16, 2007 - 01:12 PM
thank you crannie
much much ppreciated
  • black in RI
Posted November 16, 2007 - 08:47 PM
i hate soldering,,,,,
finished it now just have to epoxy it tomorrow.
  • HeadTrauma
Posted November 17, 2007 - 10:47 AM
That's what I did too. :thumbsup: I ALWAYS use rosin-core solder with lead in it if I have the option. This RoHS business is making lead solder harder to get these days. :ride:
Honda XR650L 2017
  • 0 reviews
  • Hot  35 replies
  • Hot  60 replies
  • 17 replies
  • 3 replies
