valves out of djustment running?
8 replies to this topic
  • zaxcar1
Posted November 15, 2007 - 05:50 PM
i have 2002 426.i think the valves are out. when i start it cold it stalls a lot and wont stay running. i have to restart it 3 time before it will stay running. also when cold it back fires, gives a loud pop. so is this the valves? or something eles?:thumbsup:
  • KJ790
Posted November 15, 2007 - 06:10 PM
If you've never checked the valves, it is probably time to check. They should be checked every 10-12 hours of riding. That is multiple times per season for most people. The popping when it is cold is most likely a jetting issue. The stalling is also very likely to be jetting related.
  • patcap
Posted November 15, 2007 - 06:18 PM
sounds lean to me back out the fuel screw/pilot a half turn or so and see,my bike was doing the same thing exactly like you said and i put a 42 main instead of the 40 and tinkered withe fuel screw and no more popping and it only takes a minute tops to be idleing on her own.
  • todds924
Posted November 15, 2007 - 06:25 PM
You are confused. There is no such thing as a 42 main and no such thing as a fuel screw/pilot.
  • bboyce
Since you are in MI and it has gotten cold, its a combination of lean jetting and just a cold bike. My bikes valves are in spec the jetting is a tad off and my bike will start run for 3 seconds and die for about 2 times, then after its a little warmer, it will stay running, but wont take throttle for about 10 seconds.
  • blue9red9
Posted November 16, 2007 - 12:42 PM
bboyce is experiencing the same thing I did last winter. The bike will need a little pilot screw adjustment for the winter or even a pilot jet increase maybe wouldn't hurt. I increased my pilot up one size and it helped a lot in the winter season. How does your bike run once warmed up? That's what really matters. In really cold weather (in VA that's about 20 degrees and below) I have heated my cylinder head with a hair dryer and it helps greatly on the starting and warm up. Don't jump to the worst things first... OH MY GOD IT'S THE VALVES!! but it could be checked.
  • zaxcar1
Posted November 16, 2007 - 06:27 PM
i was looking at the book and i see the the piolt jet is a 42 thats what i have. it does have a dr.d muffler. should i go bigger?
  • blue9red9
Posted November 17, 2007 - 05:35 AM
You could go bigger but you need to base your decision on how the bike runs once it's warmed up. Try the fuel screw first. I don't recall my 426 being lean in cold weather like my 06 is or was before the jet change.
  • maxtherat
Posted November 17, 2007 - 09:46 PM
Sounds like your pilot jet might be partially plugged. Clean it out before you start messing with your jetting. If you think it is lean after that then raise the needle one position(lower the clip). A 42 PJ should be good on your bike.
  • Hot  113 replies
  • Hot  47 replies
  • 5 replies
  • Hot  36 replies
  • Hot  50 replies
