how to strip epoxy from stator poles?
8 replies to this topic
  • black in RI
Posted November 15, 2007 - 03:58 PM
i'm doing the stator rewind( stripp stator of all wires cept for the ignition colis)
fitst ? is ... how doyou get the eopxy off of the stator scrap witha knife? screwdriver???
secret solvent...lol
  • martinfan30
Posted November 15, 2007 - 04:01 PM
not done this yet, but i know carb spray in can eats up alot of junk. maybe with a wire brush too.
  • Frank ZX
Posted November 15, 2007 - 04:05 PM
Maybe try aircraft stripper?
  • black in RI
Posted November 15, 2007 - 04:06 PM
grrr. i'm in the middle of it and its annoying me!!!!!
just stripped off al the copper wire.... now i'm attacking the expoxt....
sigh
  • cleonard
Posted November 15, 2007 - 04:10 PM
Nothing will dissolve it. All you can do is chip, cut, file, sand, or grind it off. Be careful though, you don't want to get into the core. The forms need to be nice and smooth or the insulation on the new wire will get scraped off.
  • black in RI
Posted November 15, 2007 - 04:14 PM
crap... i chipped it..
this is so not worth it.. and painfully slow unles i'm doing it wrong
  • black in RI
Posted November 15, 2007 - 04:22 PM
the epoxy is gray obviously... i scrape it off but i also scrape off something beige and then underneath it is bare metal... do i strip to the metal??
because there is no way to scrape jus the epoxy off.
  • TrailRiderXRL
Posted November 15, 2007 - 06:33 PM
I plan to do mine soon. If you're redoing the lighting poles then yes you need to take the metal wire off of the plastic stator pole. Once you get a piece of wire started you should be able to pull the rest . Be sure not to touch and scrape the ignition poles!
  • black in RI
Posted November 15, 2007 - 06:37 PM
ok so so i decided that to totally strip the pols of all epoxy is impossible so i just wound the stator with the wire. new thread .. different questionn
