Yz450 07 Tank Bolts Stripped :confused:
7 replies to this topic
  • Daz_426_02
Posted November 15, 2007 - 02:33 AM
Hi guys,
On a 07 450 there are 4 bolts holding each side radiator shroud in place.
The bolt closest to the back of the bike (not the one under the seat) has become seized. ( I think from the clearing chemicals i use)
When i have tried to remove the bolt the insert that is in the tank just turns. I have tried tapping the bolt to crack the seal as it were. No luck :busted:
Anyone else have this problem? Oh and its on both sides of the bike. Any suggestions on how to remove it now without buying a new tank :ride:
And before anyone asks... No i didnt over tighten them, they have seized from the cleaning chemical i use ( is my best guess) and i have since lubed each of those remaining bolts with copper compound to make sure they too don't get seized in.
Any info is much appreciated.... :thumbsup:
  • bthomas
Posted November 15, 2007 - 02:47 AM
Maybe this will help, I think it's the same basic concept. http://www.crfsonly....ank shroud bolt
  • Daz_426_02
Posted November 15, 2007 - 02:58 AM
Thanks for the link... although melting the tank leaves me a little worried..
Posted November 15, 2007 - 05:33 AM
We just went through this over the weekend:
http://www.thumperta...747#post4665747
  • clayton mclean
Posted November 15, 2007 - 06:53 PM
I have an 07 and mine did the same thing. Mine was like that the frist time i tried to take them off. How have you made out with yours.
  • Daz_426_02
Posted November 15, 2007 - 10:21 PM
Well last night i managed to drill them both out carefully.
First i put a small 3mm bit in as a pilot whole, then i used a 6mm bit. As soon as the 6mm bit got past the head of the bolt, the bolts head came off.
Now i have taken an M6 bolt and cut the head off, to basically give me a stud. Then i cut a slot into the one end of the stud with a very thin grinding disc.
Then i mixed up some epoxy and pushed it into the bolt whole and screwed the stud in. Now if when i ever take the shrouds off again, then i can at least hold the stud with a flat screwdriver while loosening the nut if the insert starts to turn again. Might not be the prettiest fix. But it sure beats destroying the tank to get it off.
:thumbsup:
  • Daz_426_02
Posted November 16, 2007 - 12:59 AM
Here is what mine looks like now....
  • bthomas
Posted November 16, 2007 - 03:26 AM
Good idea!
  • Hot  47 replies
  • Hot  28 replies
  • Hot  36 replies
