Chain Adjuster Problems
20 replies to this topic
  • TobyB
Posted November 14, 2007 - 05:31 PM
07 YZ450F, Everytime I ride/race the chain adjuster bolt on the right side will back off of the block, anywhere from 1/4 to 3/4 inch. They are tight and I do not want to go too tight and wreck the threads in the swingarm. Any ideas on how to prevent this, locktite, zipty blocks, ?????
Thanks in advance.
Toby
  • jbrooks26
Posted November 14, 2007 - 06:19 PM
Are the jam nuts missing? If they are not there then you will not get this to stop. I would not recommend locktite on these bolts as they have a tendency to sieze all on their own. Hope this helps.
Josh
  • todds924
Posted November 14, 2007 - 08:27 PM
Thanks in advance.
Toby
I highly recommend the Zip ty chain adjusters. Very trick.
  • TobyB
Posted November 14, 2007 - 09:14 PM
The jam nuts are still there and I tighten them before every ride and tighten the bolt to the chain block and the one side still comes loose. I saw the picture of the zipty blocks but dont understand how they are different from a stock setup.
Thanks
Toby
Posted November 14, 2007 - 09:34 PM
Thanks
Toby
They're prettier, and the markings are finer. They won't help this problem.
As you tighten the lock nuts, do you hold the adjuster bolt tightened against the axle, or do you let it turn a little with the nut right at the last? How much torque are you putting on your axle? Do you torque the axle first, or lock the adjusters first? When you read the blocks, do you read the marks from front to back, or back to front?
  • TobyB
Posted November 14, 2007 - 09:40 PM
I tighten the axle first then tighten the bolts to the blocks the then lock nuts last. I dont put a torque wrench on the axle nut yet, no socket big enough. When i tighten the locknuts I hold the bolts with a 10mm after I have snugged them up to the blocks. I dont read the marks, I use calipers to measure the distance.
Thanks for the help.
Toby
Posted November 14, 2007 - 10:11 PM
When you run the bolts up against the axle, you push them forward aagainst the threads in the swing arm. When you tighten the lock nuts, that pulls the bolts back against the threads in the swing arm. If there is a fair amount of thread clearance, that can cause a conflict. It can end up where the bolt is jammed against the axle by the lock nut, but is "floating" in the swing arm threads. I the axle shifts at all, the tension on the bolts is gone.
Try either of these two things:
Lock the adjusters down, and then push the wheel forward (running a rolled up rag between the chain and sprockets is one way) and tighten the axle. Or,...
Snug the adjuster bolt against the axle, but allow it to rotate clockwise (with the nut) about half a flat as you tighten it to compensate for thread clearance.
The first method works the best.
  • TobyB
Posted November 15, 2007 - 06:07 PM
Thanks for the help, I will try both the next few times I ride and hope for the best.
Toby
  • todds924
Posted November 15, 2007 - 06:29 PM
The Zip ty blocks I have are the ones that have the adjuster bolt built into the block. The adjuster bolt threads into the swingarm. There is no way they can move.
  • TobyB
Posted November 15, 2007 - 06:40 PM
So the bolt is built into the block and then it spun into the swingarm. This sounds like it is what I need if grayracers fix does not work.
Thanks
  • DPW
Posted November 15, 2007 - 07:46 PM
  • diverb32
Posted November 15, 2007 - 08:49 PM
I have the same exact problem with my 07 450f. It only started when I installed Tusk axle Blocks????? I Don't see how that has anything to do with it but I go through the same sequence as you and my right side always backs off??????
Posted November 15, 2007 - 09:30 PM
Same sequence as who?
  • diverb32
Posted November 15, 2007 - 09:40 PM
As Tonyb
"I tighten the axle first then tighten the bolts to the blocks the then lock nuts last. I dont put a torque wrench on the axle nut yet, no socket big enough. When i tighten the locknuts I hold the bolts with a 10mm after I have snugged them up to the blocks. I dont read the marks, I use calipers to measure the distance.
Toby"
Posted November 15, 2007 - 10:14 PM
Just for fun, try it my way. :thumbsup:
  • diverb32
Posted November 15, 2007 - 10:20 PM
Will Do!!
  • diverb32
Posted January 27, 2008 - 11:19 AM
BTW, your sequence worked great GreyRacer!
Posted January 27, 2008 - 12:16 PM
:cool: Works for me, too.
  • TobyB
Posted January 27, 2008 - 01:22 PM
Worked great for me also, rode it for the first time last week after doing it your way and the adjuster did not back off once. Thanks
  • todds924
Posted January 27, 2008 - 01:40 PM
Gray, I have the zip ty blocks that thread directly into the swingarrm. Are these the ones you are referring to? They aren't just replacement blocks you use with the stock adjuster bolt and nut. Ooooops, i just saw DPW's photo!!!!!!! Yeah,,,,Those are the ONES I have. Except i only use the blocks themselves, not the rest of the stuff.
  • 10 replies
  • Hot  30 replies
  • Hot  38 replies
  • On January 15, 2017
  • 5 replies
