Titanium valves/springs/retainers in a 650R?
7 replies to this topic
  • XRMANU
Posted November 13, 2007 - 03:01 PM
Does anybody have used them in a 650R?
Intake /exhaust valves + springs and retainers? Pro/cons?
Any good brands/dealers with good prices/services?
I would use them with a 680 kit and a stage 2 Hotcams,I have now Kibblewhite 1mm os intake valves and oem size Kibblewhites exhaust .
  • XRMANU
Posted November 14, 2007 - 03:31 AM
:ride: anyone? :thumbsup:
  • crmc33
Posted November 14, 2007 - 04:58 AM
Hi
Do you mean just Ti retianers with hi lift springs and black diamond valves? Or do you mean Ti valves?
I have used the former a lot on my 650L based racer with no problems
  • XRMANU
Posted November 15, 2007 - 03:52 AM
I have back diamond valves in now but want the valvetrain as light as possible , I will lighten up the flywheel also so the 680 hc piston can rev as freely as the 650. Will put a Falicon rod in to be sure. :thumbsup:
  • crmc33
Posted November 15, 2007 - 04:39 AM
FYI
If you want Ti valves then it means new suitable valve seats too
  • bork
Posted November 17, 2007 - 06:04 AM
I know less weight means less valve float on higher RPM. But what kind of RPMs vcan be safely hit on the 650? & the trade off is the Titanium wheres faster. I was going to do an engine back about 5 years ago, & put things in prossective & opted not to. Check with Rob@barnumspro.com & maybe he has done it & have input for you.
  • HeadTrauma
Posted November 17, 2007 - 10:42 AM
FYI
Yeah, usually ductile iron or beryllium bronze.
I really doubt the performance gain would be worth the cost and shortened life on anything but a maximum effort racer. Good swirl-polished stainless valves, stiffer springs, and Ti retainers will hold some high rpm and will last longer.
Ti valves alone will probably cost $120-150+ apiece, especially if they aren't a standard size already offered by a manufacturer AND if they are only sold in small lots.
  • weskc35k
Posted November 17, 2007 - 06:24 PM
Yeah what's the point.
