clutch slipping
3 replies to this topic
  • brazen red
Posted November 13, 2007 - 02:20 PM
I have a clutch slip problem on my '98 Wr400. It occurs only in top gear, but at all rev speeds.
I have fitted a complete new clutch with H/D springs and boths sets of plates (Yam stock) hoping to rectify the problem, but it remains.
I thought the clutch I removed looked OK. It looks like it was an uprated clutch as it has dimples on the steel plates, unlike the new standard yamaha clutch I have now fitted.
Someone mentioned it could be the oil type, and suggested going to mineral oil might solve it.
I am currently using semi-synthetic oil (which has been recommended to me generally as it is an old bike), against synthetic oil, as recommended by Yamaha in the workshop manual.
Or should I try going back to synthetic oil? Or none of the above?
if anyone can help I would be grateful.
All the best,
cheers, Red.
  • GCannon
Posted November 14, 2007 - 09:01 AM
Search "5th gear" ? maybe you have a top gear problem? there have been may discussions on this with symptoms similar to yours.
  • brazen red
Posted November 19, 2007 - 12:51 PM
I'm sure this is not a gearbox problem. Any other ideas anyone?
Cheers, Red
  • brazen red
Posted November 23, 2007 - 03:40 AM
I now agree - this could well be a gearbox problem.
What a pain as i've just rebuilt the bottom end!
Is there any way to be sure before I rip it apart again? Where should I look for wear, or will it be obvious. I didn't notice any wear when I had it apart....
All the best,
Cheers, Red
