Does the XR650L share a front wheel?
13 replies to this topic
  • ghrati ghoti
Posted November 12, 2007 - 08:18 AM
Is the NX650 the same? I'm looking for rotor options.
  • ghrati ghoti
Posted November 12, 2007 - 12:58 PM
*tap,tap...is this thing on?*
*crickets*
  • Old Graybeard
Posted November 12, 2007 - 01:15 PM
It's working. I hear ya!
When ya find out, let me know. I'm looking for wheel options. If I read the charts correctly Excel makes a back wheel/spoke set for an L but not a front.
  • XR650L_Dave
Posted November 12, 2007 - 02:44 PM
Bikebandit says the rotors are the same.
http://houseofmotorc...0l-2001/o/m3119
http://houseofmotorc...50-1988/o/m2464
each link, click through wheels-front wheel, item 16.
Dave
  • ghrati ghoti
Posted November 12, 2007 - 02:49 PM
Dave
The NX650 is rarer for aftermarket rotors than the L is. I was hoping for something like an XR250 or XR400 but I'm pretty sure they're different.
  • absynth01
Posted November 12, 2007 - 03:27 PM
My XR600R bolts up and my CR500R does too. For the CR, I had to turn some spacers for the proper distance on the rotor side.
  • FoolishMortal
Posted November 12, 2007 - 03:42 PM
Yep. The XRL and XR6 share a front wheel (and the rear, for what it's worth).
  • ghrati ghoti
Posted November 13, 2007 - 05:58 AM
But does the rotor bolt up? I got one the was listed for the XR650L, the package says it's for the CR125, CR250 and CR500 and it's not even close.
  • absynth01
Posted November 13, 2007 - 06:21 AM
What I did at first for the CR was double up the caliper side with TWO spacers, guess what, it is usable. I then turned down slightly less on a mill
for a single spacer. I didn't even screw with the speedo side as I run GPS. I don't know if the parts work on that side, but used the CR rim for a weekend until my new tire came tuesday. My CR stuff is not DOT.
  • ghrati ghoti
Posted November 13, 2007 - 08:08 AM
What I need to know is...will any other rotor bolt up to the front hub of an XR650L wheel.
  • bentbike
Posted November 25, 2007 - 08:51 AM
I whish I could find a definitive anwer to this one too. There are a ton of XR650R wheels for sale, but not many XRL or XR600 wheels. I wonder if any other front wheels are a bolt on.
  • Norge
Posted November 25, 2007 - 09:01 AM
XRL wheels with tires. Perfect shape, tight spokes, great tires. Sun rim rear, OEM front. PM if interested.
  • frankiewhipit
Posted November 25, 2007 - 09:24 AM
I have used a front wheel from an NX 650 on my XRL, I had to make a spacer for the left side & replace the bearings with a 17mm inner bore bearing. The axle from an NX is 15mm.
  • ghrati ghoti
Posted November 28, 2007 - 08:25 AM
Here is an update. I only found one aftermarket rotor that fits. EBC 6010D. Others list it ones they claim will fit, but do not. I had a Galfer wave rotor for the front that was not even close. If it says it fits any of the XRR bikes, it does not fit. The hub must be different because of the speedo drive. The reave Galfer wave rotor does fit nicely.
Honda XR650L 2017
  • 0 reviews
  • Hot  60 replies
  • 17 replies
  • 3 replies
