XR650L: no spark - where to start...
5 replies to this topic
  • bluerock5
Posted November 11, 2007 - 07:05 PM
My 03 "L" has been running great - and suddenly - it won't start. The fuel delivery seems fine - but the plug has no spark. tried a new plug - no spark. Is there a weak link I should check out 1st - like the coil or pulse generator. Thanks for the help in advance......
  • cleonard
Posted November 11, 2007 - 07:13 PM
The weak link on the 650L is the CDI box. It is a very common failure.
  • stepho
Posted November 11, 2007 - 07:16 PM
my 03 cdi box went out a month ago.
  • martinfan30
Posted November 11, 2007 - 08:18 PM
good starting point...
take both wires off the clutch switch and ground them both. this bypasses all safety switches.
if you still have no spark then look at the cdi unit.
  • bluerock5
Posted November 12, 2007 - 05:51 AM
Is there a way to check to see if the CDI is bad ie....can you use a meter on it?
Also, is there a good after market brand of CDI thats better than the stock Honda unit? Thanks...
  • martinfan30
Posted November 12, 2007 - 08:23 AM
not really. all you can do is verify it has all the necessary inputs.
