xr 600 electrical problems???
3 replies to this topic
  • banshee power
Posted November 11, 2007 - 11:57 AM
I am looking for some suggestions/help regarding the electrical system on my xr 600R dual sports from 95.
the problem is:
the lights don´t work,so i try to mesure the strator and come whit the mesure of -0.02 dcv on the digital multimeter.
but the mesure on my rear brake ligth is 14.30 dcv.
Will the strator need to be replaced?
reciter/regulator?
or both?
Any tips or recommendation would be appreciated?
tank´s
  • martinfan30
Posted November 12, 2007 - 08:53 PM
the problem is:
reciter/regulator?
or both?
tank´s
ok, your lights dont work but you have battery voltage at the brake/tail light?
how's the resistance at the stator?
  • bork
Posted November 17, 2007 - 06:10 AM
My buddy had problems with his dual sport kit & he talked to someone at Baja designs & they walked him thru diagnosis. & sent part that needed replacing. I would think if you get juice at rear lamp, You need to find why its not at front. Thus stator & related componants ok.
  • ZEKEDAWG
Posted November 18, 2007 - 09:50 AM
The power from the stator is AC not DC so you will have to use a different setting on the multi meter. Check the bulbs, if you have 14 dc v at the tail light it should light up from the battery power. Make sure none of the filaments are broken, and that it is hooked in.
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 22 replies
Honda XR650L 2016
  • 0 reviews
  • 9 replies
  • 3 replies
