YZ 426 fuel inlet leaking at carb-need o ring
7 replies to this topic
  • zgreen
Posted November 10, 2007 - 03:52 PM
I have searched the site and cant find my answer so please forgive me if I missed it. I need to find/buy the o rings to seal the fuel inlet where it goes into the carb and am having trouble. Just in case the "fuel inlet" isn’t the correct term or further description is needed, the fuel line comes from the petcock and goes to the fuel inlet located on the left side of the carb. The fuel inlet is L shaped with the fuel line coming in at the top and the other end going into the carb. There are 3 o rings that seal it to keep it from leaking gas between it and the carb. My local bike parts stores are....well you know. Anyway they can’t even get them. The o rings are kind of oddball with the inner and outer circumference being flat, so they may not actually be "O" rings. I checked the manual and found them shown in a diagram, but there are no part numbers or other useful info to help solve the problem. I tried experimenting with o rings from the local auto and hardware stores and I can’t find the right size. Has anyone fought this problem or able to point me in the right direction? Where am I gonna find these stupid things? Any help would be greatly appreciated. Thanks.
Posted November 10, 2007 - 04:46 PM
try Sudco
  • PATHPOUNDER
Posted June 27, 2009 - 12:41 PM
sudco has a 25 .00 minimum...which I paid last week for some other o rings...anybody have a yamaha part # for these o rings...??
Posted June 27, 2009 - 10:16 PM
Try these (calls for 3 of them):
3TJ-14564-40-00
These are listed for the '06, which has an identical looking fitting at the carb.
  • PATHPOUNDER
Posted June 28, 2009 - 11:51 AM
3TJ-14564-40-00
Thanx...on the sudco mcrofiche for the fcr mx carb..it says those rings are the same for all carbs...Ill order some and see if they work out..
  • GCannon
Posted June 29, 2009 - 03:32 PM
I had this same problem I could not buy the rings from Yamaha.
I bought the full oring/gasket kit from honda for a 450 crf I for like 22-24 dollars
I saved the other gaskets for later
Posted June 29, 2009 - 03:39 PM
It turns out that the 3TJ-14564-40-00 O-ring does if fact fit the older carb inlet, so now you can get them from Yamaha separately.
  • PATHPOUNDER
Posted July 23, 2009 - 04:26 PM
3TJ-14564-40-00
Yes they worked for me on an 01 426...Remember to order 3 ...
