newbie with drz 400 sm ?? setting sag
5 replies to this topic
  • ucatreo
Posted November 09, 2007 - 06:07 PM
I just bought an 06 sm and i have 400 miles on it in 5 days. I cannot believe how much fun I can have on that thing:ride:
I mean seriously, I just traded my gsxr 1000 and I feel like I'm riding for fun again.:thumbsup: I could go on for pages about how religious it is...but I figure you folks already know as you are reading this.
I have searched the forums and found all kinds of info on how to set up sag for the drz off road but I am curious about a road set up. I weigh 185 lbs and will only be on road or a little graded double track. I can't imagine it being more fun than it is now bone stock but I know most bikes are a little softly sprung for my weight. I see there is no external preload adjust so i figure to get new springs for the front and take advice on the shock. some static sag advice on both ends will be much appreciated.
john
  • smcalpac
Posted November 09, 2007 - 06:15 PM
Setting the sag is for the most part just as any other dirt bike. I believe the "book" amount is 100mm (about 3 3/4"). As for springs, definitely get the bike sprung for your weight. It is easy to do and helps enormously. Lasly, valving, if you ride with a passion (read fast) stiffen everything up on compression and rebound.
  • ucatreo
Posted November 09, 2007 - 07:24 PM
so use a "dirtbike" amount of sag like 100 mm and not a street sag (less) for my drz 400 sm which will only be street ridden? I have never ridden a dirt bike before but have done a lot of street riding.
:thumbsup:
  • ucatreo
Posted November 10, 2007 - 06:12 AM
I have been all over this site and other SM sites and read quite a few august opinions on sag. There is still limited consensus on the subject for SM. I have some SM racer types suggesting 25-35mm and some dirt oriented types suggesting 80-100mm sag front and/or rear:banghead:
my static and race sag are 35mm and 55mm fork
and 35mm and 100mm rear.
these are to about + or - 5mm according to the 7 yo daughter who was assisting me this morning until her feet got cold (literally) in the garage.
I feel as though the rear of the bike sits a little low when I ride, although I am having the time of my life on the thing.
Any thoughts?
  • kembro
Posted November 10, 2007 - 11:58 AM
I wound my pre load up the other day as the DRZ was getting a little saggy. I took it up until it just returns to full extension of the shock on the stand. I find even though i'm more on my toes it gives it better handling. Better turn in, with less push and absorbs bumps better. Will measure the specs, when I have a spare set of hands.
On the 17" motard wheels I run the triple clamp at the top of the forks. When on 21/18 dirt wheels, I set the triple clamp 2 marks down (10mm I think). This setup is as far as i'd go as it has just a hint of insability on gravel at 90km/h.
In the sealed twisties with the 606's, it's just brilliant in this setup. No push on the exits, just holds it's line at over 100 through most corners.
Cheers
kem
  • ucatreo
Posted November 10, 2007 - 05:57 PM
thanks
I'm figuring more preload in the shock
Maybe try for the same 35/55mm sag as the fork and go from there.
2003 Drz400s struggling at 55 mph? by kingbluey
  • Hot  65 replies
How to avoid head failure? by Maxed-out
  • Hot  44 replies
Drz400s petcock question by JEEPNICK
  • Hot  27 replies
Found Dr-Z400 12 years old "Factory PACKED" by ezkhan
  • Hot  28 replies
CRD HEADER and STOCK S SILENCER? by Alex Wilford
