Custom Extended Cables For '03XR650R
12 replies to this topic
  • WBoyce
Posted November 07, 2007 - 05:20 PM
Hi Guys, I just placed a set of risers on my 03 XR650R (riding
position is perfect - finally) Now I require longer cables. Can anyone
point me to a good supplier of these cables. I need all four both
throttle, decompression and clutch cable. Any info is appreciated.
Warren
  • knuklehead
Posted November 07, 2007 - 06:34 PM
Terry cable, they use to do custom stuff.
  • philipstjohn
Posted November 07, 2007 - 06:47 PM
Warren
Can you tell us how high your new risers are and the bars you have installed? You must be really up there... :worthy:
  • WBoyce
Posted November 07, 2007 - 07:03 PM
I have the ROX 2 inch risers e/w Renthal fatty bars with a RC bend. All my cables are border line and I have done my best to reroute them Still they are just on the edge of being stressed.
  • Billahjack
Posted November 08, 2007 - 06:46 AM
I think the bars are wider than stock in addition to the rise. I put renthals (7/8") on mine with no riser and the cables are tight .
  • TrailRiderXRL
Posted November 08, 2007 - 06:53 AM
Warren
I just put 2" Rox risers on my XRR with Renthal Hi Bends. All I had to do was reroute the cables from in front of the bars to behind the bars. (Looking at it from the riding position on the bike) I still have some length left in the cables.
  • dezracerE
Posted November 08, 2007 - 07:03 AM
Sounds like you are puttin on some "ape hangers" ?
Goin chopper on us?
Keeps the armpits dry...
  • Supplicate
Posted November 08, 2007 - 07:11 AM
The clutch cable doesn't need to be changed. Trust me OEM is the way to stick with on the clutch. I have a BRP SUB Mount and HX High bend bars, and am running the OEM clutch and decomp cable. Just route them on the back side of the triple clamp.
Now... for throttle cables, definately get extended of those. Otherwise you are asking for issues in the corners. I have a set of 3" longer ones (IIRC) sitting on the shelf if you are interested in em, they were built by Terry Cable two and a half years ago and only ran for a couple months before getting the Eddlebrock.
  • redwoody
Posted November 08, 2007 - 07:44 AM
I put the GPR Type I under the (fat) bar mount and new top clamp. Bars are Renthal CR Highs. no issues except that I had to rotate the throttle back towards the rear of the bike as those cables seem the shortest. this gave me plenty of slack. The bar ends are almost exactly 4 feet above the floor and I believe a 1/2" wider overall . Cycra Pro Bend hand guards with the clamp mounts also work quite well.
  • WBoyce
Posted November 08, 2007 - 01:45 PM
Hi, let me do alittle more testing with cable routing etc. I might be interested in your +3 throttle cables.
Warren
  • RipperFox
Posted March 16, 2010 - 07:54 PM
Been searching but nothing useful.
I got wider, taller bars and risers. Cables in front of the triple and they still dont let the slide close when the bars are turned left or right.
I gotta have new cables.
And I dont need to hear how yours do work. That doesnt help.
  • thklr650
Posted March 17, 2010 - 07:19 PM
http://www.motionpro...ustom/index.php
  • rides a big red pig
Posted March 21, 2010 - 01:09 PM
Motionpro does make them. they are available through scotts or gpr for their sub mount stabilizer kits. Happy hunting!
  • 22 replies
  • Hot  60 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 4 replies
