175lb XR650R
21 replies to this topic
  • Krannie McKranface
Posted November 06, 2007 - 06:26 PM
We are all familiar with magnesium and titanium replacement parts used on works bikes. With magnesium being a direct replacement for an aluminum part and titanium being a replacement for a comparable steel component. Magnesium has a density of 1.8 and for titanium the density is 4.7. Thus if we were able to fabricate an identical part made of magnesium that was currently made of aluminum the new part would weigh 33% less. Similarly if we were to make a titanium part that was currently made of steel the new part would weigh 40% less. These types of replacement parts are typically described as Unobtainium. Hypothetically, if we replace all of the steel parts with titanium and all of the aluminum parts with magnesium the XR-650R would weigh 198 pounds! Wouldn’t that be great! Add to this savings what we could gain from elimination and modification and it might be possible to make a 175 pound XR-650R.
**taken from: http://www.srcinc.net/html/101-03.html
  • Nate R
Posted November 07, 2007 - 12:33 AM
Eh, why metal? That whole subframe could be done in Carbon Fiber and be even lighter!
  • Billahjack
Posted November 07, 2007 - 07:20 AM
Don't forget to put a vacuum in all the closed chambers like frame tubes, handle bars, hollow bolts, etc. so you can reduce weight even further.
Ever see titanium bearings or gears? I haven't. What's your plan there?
  • cleonard
Posted November 07, 2007 - 07:42 AM
All it would cost is $250,000. :worthy:
  • bosshog
Posted November 07, 2007 - 03:57 PM
Run your tires at 5 lbs and save some weight there too.:worthy: Sure would be nice if you could trim the fat. I think it would be much easier to take the motor and put it in something else or build a frame around it. Stuff it in a 2000 something CR80 woohoo watch that go.
  • Big Red Paul
Posted November 07, 2007 - 04:05 PM
Suggest: Remote control device. Eliminate the human weight factor.
  • jsb223
Posted November 07, 2007 - 06:30 PM
A simple tricycle built with F-14 materials and specifications would cost $17,000 in 1990 dollars...
That XR project would be insanely expensive...
Posted November 07, 2007 - 07:19 PM
...AND absolutely necessary.
  • Billahjack
Posted November 07, 2007 - 08:48 PM
Have you ever wondered if the 300+ pounds of a XRR or XRL is what lets it ride smooth and fast through choppy nasties when you see CR250's hopping and chattering all over the place? I have. I also appreciate when the XRR plants that rear tire for traction up hill climbs instead of bouncing around like the 2-smokes.
Maybe it doesn't change direction that fast, but I feel it dampens much of the motion that you get on lighter bikes when you are riding at higher speeds.
  • weskc35k
Posted November 07, 2007 - 11:50 PM
I think you're onto something there Bill.
  • scalejockey
Posted November 08, 2007 - 05:42 AM
yes... that's why I like my piggy ....smooth rider.. cadilac baby!!!
  • XR650L_Dave
Posted November 08, 2007 - 08:46 AM
That's why I call it my 350lbs trials bike!
Dave
Posted November 08, 2007 - 10:42 AM
Yeah, that's the same argument Ford used to make about thier overweight Pinto: "it has more road-hugging weight".
Yeah, until you try and turn, stop, go up hill, etc.
  • martinfan30
Posted November 08, 2007 - 11:33 AM
i think bj has a great point!
  • Bigmutha
Posted November 08, 2007 - 06:02 PM
I love my BRP because it is a heavy pig. It handles great.
  • gaspipe
Posted November 08, 2007 - 06:47 PM
If money was no object, a feller could use beryllium alloys for the frame, bars, fork sliders, subframe, etc., and save more weight.
You might be able to push the cost of the bike to a million or more using stuff fabricated with beryllium - one of the more unobtainable unobtainium metals.
:worthy:
  • The Regulator
Posted November 08, 2007 - 06:54 PM
I say just do it Krannie! Refi the house and just tell the little woman that it is completly necessary! It's for the team!
:worthy:
  • Old Dog
Posted November 08, 2007 - 07:15 PM
:worthy:
Why stop there?? :worthy:
I'm pretty sure there's some Anti-Gravity technology out there somewhere, in some Top Secret Government Lab that could be applied to the situation. If you could cough up enough spondolas to the right person, I'm sure they'd slip you the technology under the table ....... say a few Billion dollars (something in the Bill Gates range). Then the actual gravity induced weight would be inconsequential. The only problem with this scenario is that it would be hard to keep the rear wheel planted firmly on Terra Ferma, thus reducing the traction quotient of the equation :worthy:
  • RC30
Posted November 12, 2007 - 01:34 PM
Just a little example of the exotic materials can do.
Posted Image Posted Image
This bike was a '96 Husqvarna TE 610 SM, it weighed 273 lbbs.
In 1997/1998 Poggipolini -www.poggipolini.com- (do you know NCR?) changed every single part of the stock bike with a similar in titanium/ergal/carbon fiber.
A little part list:
[COLOR="Red"]TITANIUM[/COLOR]
Frame, rear frame, triple clamps, swing arm, front fork pipes, exhaust system, foot pegs, side stand, engine covers, gear change pedal, spokes, connecting rod, intake and exhaust valves, all pivots and all bolts and nuts and more....
[COLOR="red"]ERGALl[/COLOR]
Rear shock absorber, wheel hubs, nipples, handlebar and more.....
[COLOR="red"]CARBON FIBER[/COLOR]
Side panels, fenders, lower seat (sorry) and more.....
[COLOR="Red"]STEEL[/COLOR]
Crankshaft, balls of ball bearings and.......and few other.
After the "care" the bike weighed...............[COLOR="Blue"]202[/COLOR] lbbs.
With a front fork like rear shock absorber (ergal, without springs), the weight would have become to [COLOR="Red"]196[/COLOR] lbbs.
I love this bike.
Piero
Posted November 12, 2007 - 02:10 PM
A little part list:
I love this bike.
Piero
...oooohhhh... now we are talking..........
Honda XR650L 2017
  • 0 reviews
  • 22 replies
  • Hot  186 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
