ignition key
5 replies to this topic
  • Rugged
Posted November 06, 2007 - 02:31 PM
at some point did they have keyed ignition on xr 600 r?
  • cleonard
Posted November 06, 2007 - 04:00 PM
No they never had one. All you need to do is buy a key switch and use the kill switch wire to ground. That is all most bikes do to stop the engine from running.
  • Krannie McKranface
Posted November 06, 2007 - 04:52 PM
....and you don't need to buy the one on ebay for $65.00. Any motorcycle key switch will work, and many sell for around $ 20.00.
  • kuritaro9
Posted November 07, 2007 - 05:12 AM
it depends where the bike came from. i live in japan, but my xr600 is an australian model.(lean CA spec jetting ,restricted carb insulator, but no smog pump) and it came with lights turn signals, a steering lock and a keyed ignition.:worthy:
  • kuritaro9
Posted November 07, 2007 - 05:20 PM
if you need, i can try to get a part# for the ignition, and see if the harness part numbers are the same as the stateside R models...
Posted November 07, 2007 - 05:27 PM
Baja designs sells a Honda oem ignition key for under $ 20.00
