Rear foot brake pedal
2 replies to this topic
  • mightymart
Posted November 06, 2007 - 11:13 AM
Is there a mod to make the XR650R rear brake pedal a little wider ? I find that sometimes I miss the pedal as it is so close to the caseing, I thought of maybe bending the pedal out but if it breakes it could lead to costly mistake, Even if that did work it would probably make the pedal weak.
  • Krannie McKranface
Posted November 06, 2007 - 12:12 PM
You can weld on a larger footprint, but I think once you get used to the stock pedal it will be fine.
  • wcorbett
Posted November 06, 2007 - 07:02 PM
From the title I thought you were refering to some sort or front and rear foot:D
