XR600r bolt torque values
4 replies to this topic
  • asf
Posted November 04, 2007 - 08:57 PM
I cant find my repair manual, can someone help me out with torque values:
-Steering stem nut (the hex one)
-Steering stem spanner nut (the toothed one)
-Front axle
-Rear axle
-Motor Mounts (I remember 2 sizes)
Thanks!
  • cleonard
Posted November 04, 2007 - 09:09 PM
from my Clymer
steering stem nut 70-100 ft-lbs (I did 80)
f axle 36-62 ft-lbs (92 on 60)
r axle 58-80 ft-lbs (91 on 70)
The bearing preload nut isn't really torqued. It is tightened to 1 to 1.5 ft-lbs. You tighten an turn the stem lock to lock. Then re-tighten and do the lock to lock thing. Repete one more time.
  • asf
Posted December 11, 2007 - 11:21 AM
Anyone know the values for:
-Motor Mounts (Large + Small are different?)
-Rear shock frame mount (upper shock bolt)
-Rear shock prolink mount (lower shock bolt)
  • Bennito
Posted December 11, 2007 - 12:17 PM
looks to me like 10mm engine mounts are torqued to 36 ft lbs. 8mm engine mounts are torqued to 20 ft lbs.
  • Bennito
Posted December 11, 2007 - 12:18 PM
rear shock upper mount is 33 ft lbs.
lower mount is 20 ft lbs.
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  186 replies
  • 17 replies
  • 3 replies
  • Hot  60 replies
