Weird idle, hiiigh,loooow
5 replies to this topic
  • dylanr
Posted November 04, 2007 - 05:41 PM
2000 xr650r uncorked, i get the idle set with the nob, then after it warms up, it idles about 500 rpms higher, if i snap the throttle, it idles back down, this makes it impossible to set the idle right. i took the carb apart, and it was really clean inside, i blew out the jets, and tried to reset the pilot screw, but that was really hard with such a wacky idle. anyone have any ideas, air leak maybe?
thanks
  • hondacrf150f1
Posted November 04, 2007 - 05:46 PM
When i start my bike on these cold fall mornings at 20-40 degree's outside i have to hold the throttle open slightly to keep the idle up, but it still idle's at 1000-1200 according to my vapor. When its warm its up around 1500-1600, not saying that i have a problem with it but whats the fix.
  • cleonard
Posted November 04, 2007 - 06:10 PM
Could be an air leak, but what you describe sounds more like sticky cables and/or throttle tube. The carb slide can wear too, but it's usually only an issue on real high mileage bikes.
  • dylanr
Posted November 04, 2007 - 06:44 PM
the cables on the carb arent tight like they are sticking, they have a little slack
  • XRMANU
Posted November 05, 2007 - 01:33 AM
Pilot nozzle too small?
  • BWB63
Posted November 05, 2007 - 08:31 AM
Have you adjusted the idle mixture screw? What pilot are you running?
  • Hot  29 replies
  • Hot  60 replies
  • Hot  35 replies
  • 9 replies
