My bike is lowering itself???
6 replies to this topic
  • ivesy
Posted November 02, 2007 - 06:46 PM
Hi there, has this happened to anyone else? Last few rides I have done have been at a track with some decent size jumps and now the ground clearance has reduced by at least an inch (my stand wont slide underneath the bike anymore). I had a couple of hard landings but nothing too bad. My tyres arent flat and the forks havnt shifted up in the clamps. Any ideas to what has happened to the suspension on my bike? FYI its an 06 with 23 hours on it.
Cheers guys.
  • todds924
Posted November 02, 2007 - 07:27 PM
Cheers guys.
Check your sag on the shock. I've had to adjust mine a few times on my 06.
  • KJ790
Posted November 02, 2007 - 07:33 PM
If you've never greased the suspension bearings, that is most likely your problem. The bearings have bound up and the suspension won't rebound all of the way. If this is the case, you have a lot of work ahead of you and you will never make that mistake again. If you have greased everything, then it is possible that your lockring on the shock has come loose and the preload ring is backing off. If this is not the case then something must be broken.
Posted November 02, 2007 - 08:38 PM
Your brand new spring has settle in a little is all that is.
  • KJ790
Posted November 03, 2007 - 06:03 AM
I've never seen a spring settle in over an inch, especially after is has over 20 hours on it. From my experience the spring settles in in the first 10 hours and unless I gain weight, my sag stays pretty much the same.
Either way, you needs to get the race sag set correctly. This would eliminate some of the posibilites. If it is just the spring settling in, then you will adjust for it. If it is a loose lock ring, ou will find it when you go to adjust your sag. If it is frozen bearings, when you lift up to check the free sag, it will stay up and when you press down it will stay down pretty far (I've seen this happen to a friend who never greased his).
Posted November 03, 2007 - 06:14 PM
KJ,
You're correct on all counts, but we don't really know if it actually dropped an entire inch, or when it did most of the settling. The Ti springs on the '06's do stuff that steel doesn't, anyway. I reset the one I bought new about 3 times after I first set it up.
But, in any case, the fix is exactly as you have outlined it.
ivsey,
Might want to read:
Setting your Sag
and:
Using the Sag to Check Your Spring Rate
  • ivesy
Posted November 03, 2007 - 07:52 PM
Thanks guys, my bearings are still nice and lubed so it must be the spring. I have never heard of this happening before to such an extent so its great to know its normal. :worthy:
