Oil overfill xr650
6 replies to this topic
  • absynth01
Posted November 02, 2007 - 08:24 AM
I overfilled my oil. Doing to many things at once, I had forgot I already filled the bottom end:bonk: . It's already drained to the proper level. Any problems leaving the to much oil up top?. I know if the case was full thats a problem, but don't see problem overfull up top. Anyone?
  • cleonard
Posted November 02, 2007 - 08:27 AM
It depends on how much over it is. If it is a lot it will get blown out the breather and cause a big mess. It's easy to just let a little out of the frame tube drain until you get it back to the correct amount.
  • ghrati ghoti
Your L?? How do you fill the bottom end?
  • mikey 4410
Posted November 02, 2007 - 08:32 AM
my bike was over filled and run for a while......ruined the valve guide seals and makes the bike use 1lt oil ever hour !!!!! ridiculus
  • dezracerE
Posted November 02, 2007 - 02:34 PM
Drain some from the lower drain bolt.
If there is not sufficient room in the top resevoir, the return line may build pressure and cause???????????
At least oil leaks.
  • janner
Posted November 02, 2007 - 03:56 PM
If unsure, I would drain it to empty then put in the right amount of new oil in.
I change my oil so frequently that I have never had to top it off :worthy:
  • Krannie McKranface
Posted November 02, 2007 - 05:14 PM
I change my oil so frequently that I have never had to top it off :eek:
:worthy: :worthy: :worthy:
  • 9 replies
  • Hot  60 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
