wr/yz wheel swap?
2 replies to this topic
  • mikeythefokker
Posted October 31, 2007 - 06:50 PM
I have an 07 wr450 and I bent my back rim up pretty bad a few weeks ago. I found a set of yz450 wheels that are off of an 04(i think) and the rotor doesn't seem to fit right in the caliper. ***? Did I just put my wheel on crooked, are the spacers not symetrical(used my wr ones) or do I need to shim the rotor? I would really like to make this rear wheel work so that when I get the stocker fixed I have 2 sets of wheels. That would be really convenient. I would like to know though if this is a lost cause or anything, before I really get into it and it melts my cranium. Thanks.
  • WGP
Posted November 01, 2007 - 07:03 AM
The YZ has a 19", WR 18" rear. I don't think it will work.
  • matt4x4
Posted November 01, 2007 - 07:24 AM
19" or 18" wheel should not matter, it's all about the hub and rotor and caliper.
The 04 YZ and WR share the identical brake/hub/disk components, however, there is a difference between the 04 and 07 components, so I believe the brake has been redesigned.
I've checked on line, and the hub you have on your 07 is identical to the 04 WR/YZ hub, so you shouldn't have to do anything but use teh 07 spacers and 07 rotor to make it work properly - you'll just have a 1" larger rim on the bike.
Go here to cross reference your part numbers and verify:
http://www.cyclepart.../2/default.aspx
