DIY stator rewire
4 replies to this topic
  • platterdr
Posted October 31, 2007 - 05:53 PM
I've heard about this but have questions.
1. are there step by step instructions on this site? I looked but no luck
2. are there any downfalls to doing this yourself?
3. how will I no my voltage when done?
4. can't think of 4 but i'm sure I will later
BTW this is on a 650L
  • cleonard
Posted October 31, 2007 - 07:08 PM
The stators on the off road bikes come with most of the poles on the stator not wound. Not so with the 650L. It has all the poles already wound. There is not anything to be gained by rewinding. It also uses a 3 phase regulator so the winding is a little different that the single phase used on the dirt bikes.
I think that the 650L is rated at 180 or 190 watts.
  • platterdr
Posted November 01, 2007 - 12:49 PM
So if I do electrical add on's such as hardwire GPS,12 volt outlet for compressor,heated grips and maybe wire for heated vest. This will not effect my bikes electrical system?
  • martinfan30
Posted November 01, 2007 - 12:58 PM
just need to add up the total wattage use of all the accessories.
  • cleonard
Posted November 01, 2007 - 12:59 PM
Just add up the watts and be sure it is under the max. To be sure the battery stays charged it might be better to keep it under 150 to 160 or so until you get some experience with how many watts it actually makes. Don't know what the baseline electrical usage is but I would guess between 75 and 85 watts. That leaves 90 to 100 or so to play with.
The alternator only makes full wattage at mid RPMs. At idle the output is a lot less, so when you have a max load don't idle for long. For those first tests at max wattage a voltmeter would be a good idea so you can be sure that the battery stays charged.
