xr650L hotcam report
101 replies to this topic
  • martinfan30
Posted October 31, 2007 - 05:33 PM
well i got home today after installing the stage 1 cam last night. i set the idle at 2500 for 20 minutes. temps all looked good(had fun with my bluepoint ir gun!). took it out after and first thing i noticed was the low end was not quite as punchy. mid range was better and top end was DEFINATELY better. being at 4300 ft. with 158/52 jetting 2 turns out and a pod filter, i decided to up the main to 160. any one have any jetting advice or is this close enough for my situation?(fcr 41 carb). before 2 nd gear wheelies were tough with some clutch work, now just a tug on the bars gits it up and keeps wanting to go up! now i have to get a 10.5 to 1 piston i think.
overall, easy job, no leaks and some power increase mid-top, with a little loss of bottom. this i think may come back with a hi comp piston? happy i did it though.
  • Bibleman
Posted October 31, 2007 - 06:20 PM
I'm glad to hear that your project went well:applause: I'm a bit disappointed hearing the results though. I have a Hotcams stage one cam sitting on my workbench and was thinking about installing it, but if I'm just going to move the power band around a little, I'm not sure I'd go through the trouble.:worthy:
  • martinfan30
Posted October 31, 2007 - 06:32 PM
its not that much trouble though. the overall power gain is worth it, IMHO. maybe i made it sound like the bottom end is dead, its not. i think there is some jetting changes to deal with still. i also think that if i were to do it again i'd put the hi comp piston in at the same time.
another thing, feeling that mid - top end hit, is VERY cool!
  • Bibleman
Posted October 31, 2007 - 06:37 PM
Was yours the Hotcam? Also, what kind of manual did you use, the factory Honda manual or a Haynes type?
  • martinfan30
Posted October 31, 2007 - 06:40 PM
yes the hotcam part # 1004-1. i used the honda manual. i also found out the cam card didnt come with the cam. so i found online the int is .15mm and exh .2mm(valve lash). did you get a "cam card" with yours? and what does it say for valve lash?
  • Denn10
Posted October 31, 2007 - 07:59 PM
what gearing did you test it with? your 14F
  • crmc33
Posted November 01, 2007 - 01:04 AM
No Cam card with my recent hotcam tho I did get one with my original one I bought 5 years back. I thinks its a good idea to set the tappets on the large side with any hi performance cam.
Its interesting to note that the hotcams come with the sprocket holder built-in now. You used to have to swap the one off the Honda cam onto the hotcam. Theyre a very nice cam I think, very well made for the money.
Not as punchy as the HRC cam but then again it also doesnt need short valve guides/race springs etc, so is an easy upgrade.
  • absynth01
Posted November 01, 2007 - 03:59 AM
I've got a hotcam in my bike as well as 10.5-1 piston. I bought the bike with a lot of work done to it. It was well done and taken care of setup for the road. I have never ridden a stock L, but now you make me wonder how much of a dog a stocker is. I bought the bike because i'm ridding with a 650R and they are a B%tch to reg here in NY. This L is close to a uncorked R. My 600R,650L and 650R are all close with the 650's slightly better. I do like the 600 better on trails, but still the selling point for me was the button. People say they can get hot in trails, but have found out the R will get quite hot and spit coolant sometimes. All in all I think the L with the right mods can be a good performer off road, with the road title(factory), and the e-start!!Good luck on your build!!!!
  • philipstjohn
Posted November 01, 2007 - 04:42 AM
Is your "R" uncorked and properly jetted? As soon as mine was dialed in, it has not overheated or spit coolant since. I do notice the coolent level in the tank rise when running slow or at idle, but it has not boiled over since it was properly jetted.
  • Kawabuggy
Posted November 01, 2007 - 05:48 AM
For the record, the biggest improvement I noticed with my bike was going to the high compression piston. The piston update was AWESOME!
Then I put in a Hotcam and noticed a little increase in power.. Then I installed full performance exhaust, and that added a little bit more..
Lastly, I jetted the bike, and that made a fairly big improvement. The piston though was the key to all of it! Maybe I did it backwards, but if I had to do it again, I would still do the piston FIRST as it gave me the biggest increase in power across the board.
  • machman
Posted November 01, 2007 - 06:20 AM
I'll be able to throw some feedback in here as well in the next couple weeks. I'm just waiting for my Kibblewhite valves and OEM springs to arrive before I can install my Hotcam, 10.5:1 piston, and FCR pumper.:worthy:
  • martinfan30
Posted November 01, 2007 - 06:38 AM
15/48. i'm thinking of going 14/48.
  • martinfan30
Posted November 01, 2007 - 06:41 AM
they truly are dogs stock. what jetting and what carb you run?
  • martinfan30
Posted November 01, 2007 - 06:42 AM
droppin' a lot of cash at once, nice!
  • Frank ZX
Posted November 01, 2007 - 07:05 AM
Glad to hear your happy with the cam swap.My cam and exhaust should be here any day now.I can't wait!
  • Frank ZX
Posted November 01, 2007 - 07:17 AM
Martinfan,Did you degree your cam?I have a cam degree kit new in the box.Is it worth the effort?
  • martinfan30
Posted November 01, 2007 - 07:30 AM
not necessary to do unless using adjustable cam sprocket.
the hotcam has a fixed flange that the sprockett bolts to.
also a tip, if you have a honda , manual order the tensioner tool. makes it much easier! i did it with out but kid of a bitch. plus the spring that rests(under tension) against the inside of the head scraped a little aluminum off during reinstall.
  • absynth01
Posted November 01, 2007 - 07:37 AM
Yes, but this was the extreme of my use. Slow,muddy, swampy trail-lots of gas to stay afloat. I did see a heavier radiator cap mentioned here. This is probably the fix for that. I didn't say the L ended up being better performance wise, but love that e-start, especially in hairy situations!!
  • martinfan30
Posted November 01, 2007 - 07:44 AM
its saved me once or twice!
  • TDC71
Posted November 01, 2007 - 01:16 PM
Hey Martinfan did you change out that o-ring on the tensioner pin?
TDC71
  • Hot  60 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 7 replies
  • Hot  35 replies
  • 0 replies
