XR650R Front axle play
4 replies to this topic
  • froride1
Posted October 31, 2007 - 08:25 AM
I noticed a little side to side play in the front wheel on my XR650R. I have had a set of Supermoto wheels on it for a few years and they have no play from side to side. While swaping wheels back to the stockers I noticed about .030" of side to side movement. I took it a part and looked eveything over and everything looks fine. I thought it might be the wheel bearings or the spacer in the hub so I popped the bearings out and they are fine. I put all the parts spacers and bearings on the axle and installed it in the forks, torqued it down and the slop is still there. All the parts can slide a little on the axle. I don't know if this is a problem or not and if it is I'm not sure how to get rid of the slop without machining new spacers.
  • Billahjack
Posted October 31, 2007 - 08:48 AM
My guess is that it is either bearings or that you didn' push the forks together when you tightened the axle clamp on the right fork.
  • bigtooth
Posted October 31, 2007 - 09:22 AM
I bet that its the bearings and that you just couldnt tell they were worn with out the axle being through them acting like a lever.
my .02
  • froride1
Posted October 31, 2007 - 09:35 AM
Yeah, I'm thinking the bearings also. The weird thing is they look perfect and spin nice and smooth. But it's the only part that would wear out. I guess after 7 years I should replace the bearings weither they look like they need it or not.
Thanks
  • slowxr
Posted October 31, 2007 - 10:47 AM
I had the problem you described with my rear wheel. Bearings felt good but after replacing them, the movement went away.
Another vote for wheel bearings.
Washington
  • Hot  32 replies
  • Hot  29 replies
  • 4 replies
  • Hot  60 replies
