rim black anodize
12 replies to this topic
  • 5valve
Posted October 31, 2007 - 07:23 AM
Need input.
Want stock rims in black, so want them anodized, bud dont know if I shoult have them sand blasted prior, or just clean them.
Blasting would probably do no good to smooth alu surface?
  • suzukipoo
Posted October 31, 2007 - 11:41 PM
Just get it polished to a mirror finish, the smoother the rim the better the anodizing!
  • Birdy426
Posted November 01, 2007 - 05:34 AM
Stock rims are already anodized clear. You need to strip that off first or the black anodize will not "take". Sand blasting will give you a really crappy looking surface. Polish with scotchbrite and progressively finer polishing compound or sand with 600-1000 grit paper to remove the anodize and give you a good looking surface for the black.
  • 5valve
Posted November 01, 2007 - 02:25 PM
Is there a chemical or electrical procedure to break the anodizing effect, sort of reverse anodize.
  • suzukipoo
Posted November 02, 2007 - 01:22 AM
When you take it to be anodized they dip in a path of acids, rinse with baking soda solution, polish it and then re-anodize in the color you want and seal with another solution!
  • 5valve
Posted November 02, 2007 - 04:32 AM
Youre right, took them to the shop, they do it all.
  • dugabrams
Posted November 02, 2007 - 06:50 AM
How much out the door?
  • 5valve
Posted November 02, 2007 - 11:27 AM
Have no clue, will tell, hopefully end of next week.
  • 5valve
Posted November 07, 2007 - 12:59 PM
22 $
un-anodizing, polishing?, anodizing.
Dont know the result yet, pick em friday.
  • 2grimjim
Posted November 07, 2007 - 01:11 PM
Why don't you just get them powder coated instead. It's cheaper, faster, and will probably hold up just as long.
  • 5valve
Posted November 08, 2007 - 01:08 PM
Dont believe that added colour layer will hold up as much as already proven and tested anodizing, as all bikes have it from natural, red, blue to black colour.
  • 5valve
Posted December 14, 2007 - 07:45 AM
all done. Consider, rims are 8 years old.
from distance it will look nice.
Yes, EXCEL text is gone now.
  • redswr
Posted December 14, 2007 - 05:13 PM
my rims are 8 years old too... i used a Marks-a-Lot marker though. not sure on how it will hold up though compared to your anodized ones.
