Uni Filter with high flow cage & swing arm tool
12 replies to this topic
  • motoxtreme
Posted October 30, 2007 - 06:51 PM
:worthy: Hi, I just bought a '07 XR650R and was wondering does anyone know where I can buy the newest air filter from UNI that has the high flow cage/frame with it? Also, regarding the special lock nut wrench for the swingarm, does anyone make these tools (motion pro, ect.) other than Honda? Thanks.
  • hondacrf150f1
Posted October 31, 2007 - 05:01 AM
Buy the less restrictive air box screan from XRs Only, also, incase you havent done it, get the smog removal kit from XRs Only, all 2007's come with the smog pump.:worthy:
  • Billahjack
Posted October 31, 2007 - 08:52 AM
I bought the XR's only backfire screen. It didn't fit well. It went with my old bike when I sold it. It was forced into the air box and then has gaps in some places between the edge of the airbox and the screen. I'm not convinced that it flows much more air than the stock mesh.
I am running the UNI air filter with the high flow cage (UNI) and no backfire screen. Last weekend, I dumped my bike and flooded it. When I started it, it backfired. Later I checked out the air filter and it singed the backside of the foam pretty good. I'm thinking of installing the factory backfire screen but removing a couple layers of the mesh for better flow. I think I saw ths on someone's website.
  • bigtooth
Posted October 31, 2007 - 09:19 AM
I have the same problem with my UNIs, a couple of backfires and the innner layer of foam is toast.
  • porterdog
Posted October 31, 2007 - 11:07 AM
If you a) put an ignition switch in and :worthy: remember to flip it to 'off' when clearing you can avoid the backfire.
The special swingarm tools are easy to make- I followed Eric (the Haymaker's) site:
http://www.xr650r.us/preload/
  • motoxtreme
Posted October 31, 2007 - 11:21 AM
Thanks for all the info. These are the following items that I have performed on my new bike: 1. removed the smog pump with xr's only kit. 2. rejetted the carb with the powerup jets and needle plus the intake. 3. drilled out the muffler tip. 4. Replaced the stock thermostat with xr's only. 5. removed the snorkel and plastic square piece in the airbox. 6. I purchased the backfire screen from xr's only and I too agree with Billahjack that I am not impressed with its fit. I also bought a uni filter from xr's only as well and it was only later while looking around on the web that I saw some uni filters coming with the high flow cage. But now, I'm thinking that I may run the stock backfire screen with the uni filter so I don't burn up my filter. Thanks porterdog for the info on the swingarm tool.
  • bigtooth
Posted October 31, 2007 - 11:57 AM
Your right holding the kill switch while clearing out a flooded pig will cure most of the backfire issues.....:worthy: At $30 a wack for a filter I will start to make that a habit.
  • Billahjack
Posted October 31, 2007 - 12:23 PM
Thanks for the backfire tip
  • Denn10
Posted October 31, 2007 - 12:29 PM
What is that swingarm preload tool used for??? im a L owner but curious.
  • porterdog
Posted November 01, 2007 - 06:57 AM
Preload is kind of a misnomer; it actually allows you to set the clearance between the parts that clamp the swingarm at the front pivot.
Regarding starting a flooded (crashed!) bike, I've recently been using Bruce B's 'race' technique. Get on, open the throttle wfo, clamp the front brake, and KICK! (Errr.... it's good to let go of the throttle right away if it starts.)
You can often get a one-kick refire this way.
  • bigtooth
Posted November 01, 2007 - 07:33 AM
I read that also on his site, and tried it also, works about 2 out of 3 times for me.
  • porterdog
Posted November 02, 2007 - 07:14 AM
Yeah, that's about what I find too. Makes you grin when it does, though- the pig roars when you get it right!
  • bigtooth
Posted November 02, 2007 - 07:54 AM
Yeah, the first time I said right out loud, 'Holy sh*t, he was right!'
  • Hot  60 replies
  • 17 replies
  • 4 replies
  • 3 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
