14 vs 18 gauge when re wrapping the stator
9 replies to this topic
  • black in RI
Posted October 28, 2007 - 04:19 PM
i accidentally bought a 14 gauge not 18 gaue wire to wrap the stator.... i'm assuming this is an issue and i'll just return it..
If i can use the 14 gause let me know.... i'm sure i cant as i wont get te expected output vs 18 gauge
  • SCOTTTO92
Posted October 31, 2007 - 11:35 AM
i have wrapped a few xr650 stators and I have never heard the results of a stator wrapped in 14 AWG...... might be a little large by the time you are done... how many wraps per pole and how many poles do you plan to do? i used 18 AWG everytime...
  • cleonard
Posted October 31, 2007 - 11:48 AM
The main concern is getting enough turns with the larger wire. If you are winding only one coil using all the poles it should be good. The bigger wire is too fat to get two separate windings with enough turns. The benefit is a little larger current capacity of the larger wire.
  • suharianu
Posted October 31, 2007 - 12:30 PM
14 gauge is almost twice in diameter then 18 so you wont be able to
put enough windings therefore not enough voltage
  • black in RI
Posted October 31, 2007 - 01:47 PM
that;s waht i thought. i ordered 18 today. i must ahve accidentally ordered 14 g... anybody want to buy 14 g :worthy:
  • cleonard
18 gauge is 1.02mm in diameter and 14 gauge is 1.62mm. That makes it 60% larger. However the stock coil only uses 4 poles if I remember correctly. If all 10 poles get wound there will be more turns than the stock unit has in only 4. Even if the wire is twice as big you still end up ahead because there are 2.5 times as many poles to wind. The voltage should be fine.
  • black in RI
Posted November 01, 2007 - 06:39 AM
I played it safe and bought the 18 gauge.
how much voltage output can Iexpect after rewinding. I plan on trying to run some heated gear.
  • cleonard
Posted November 01, 2007 - 08:49 AM
The voltage is proportional to RPM. If it puts out 12 at 2000 RPM, then it's 24 at 4000 and 36 at 6000. This is why a regulator is used. With the regulator you should see 12 volts all the time.
  • suharianu
Posted November 01, 2007 - 12:12 PM
If I am not mistaking there are 2 separate low voltage windings one for ac regulator and the other for dc regulator plus 2 poles for the high voltage that feeds the Cdi-so I am not sure he will have enough poles to wind on.
  • cleonard
Posted November 01, 2007 - 12:31 PM
The stock stator has 12 poles. Two are used for the ignition high voltage winding and four are used for the lighting coil.
The XR650L uses more or less the same stator form, but it is wound differently. There is no high voltage winding and all 12 poles are wound in a three phase delta connected winding.
