Scotts Damper mounting question
9 replies to this topic
  • Team_Oatmeal_Pie
Posted March 24, 2002 - 04:04 PM
I have purchased a scotts weld on kit for a 00 wr400 and am looking for feed back on mounting it. Has any one done this. I have the stock triple clamps but run the Thumper 1.5" risers, and scotts says weld on is the only way to go. am I correct in thinking I need to grind the top triple clamp so get the tower pin to fit between the oil filler stem and the triple clamp and will this weaken the clamp?
I also have another scotts for sale for those who may be interested
  • Dodger
Posted March 25, 2002 - 11:49 AM
The area of the upper triple that you need to grind away is useless material. It serves no structural purpose what so ever. Grind away :) !
Dodger
  • Private_Joker
Posted March 25, 2002 - 01:20 PM
I'm interested in the damper. I sent you a PM.
  • Brian_in_Long_Beach
Posted March 25, 2002 - 02:31 PM
I have a '99 WR but I use the bolt on tower - around the oil filler. I run an Applied Racing TC & Thumper Racing +1.5" BOLT-ON bar mount/risers. Not sure why you couldn't use the bolt on tower...
Brian
  • mcarp
Posted March 27, 2002 - 09:41 AM
Yep, you have to grind it quite a bit. Keep the same wall thickness as the rest of the clamp and you'll be fine.
  • Butterman
Posted March 30, 2002 - 02:48 AM
New mounting system for Scotts dampenersPosted ImageThis WR has a number plate,we're working on the setup that will allow for keeping the headlight.This setup allows for all different bar positions/triple clamps,and allows for a nice soft bar pad.
  • leif
Posted March 30, 2002 - 03:04 AM
Do you still have the other for sale? How much?
  • bman
Posted March 30, 2002 - 10:35 PM
Boy that's got to be tough to adjust when riding!
  • John_H
Posted April 01, 2002 - 12:07 AM
Good point!
After a few miles trying to catch up... Don't need to adjust.
[ April 01, 2002: Message edited by: John H ]
  • Scuba_Steve
Posted April 06, 2002 - 09:28 PM
I installed a Scotts bolt-on damper with an Applied triple clamp. I didn't want to go to the weld-on style because I wanted to be able to remove it later if I sold the bike. Using the Applied clamp made it unnecessary to do any grinding.
I did have some problems with the bolt-on mount when I didn't follow the installation instructions exactly. You have to trim the upper bearing seal and do a little bit of grinding to the frame welds at the neck to insure the clamp fits the neck precisely. It slipped loose a couple of times, so I finally used my die grinder to eliminate the paint under the clamp and then I JB welded it into place.
Now that I've written this, maybe the weld-on kit would have been easier... :)
