dirty coolant
7 replies to this topic
  • nolzey
Posted October 28, 2007 - 04:09 AM
i was filling up my coolant today ( yzf 400 99 ) and i noticed the coolant looked like there was dirt in it and the water was a black colour. still looked like water just a dark tinge to it. just had the head done and new gaskets 20 hours ago. any ideas on what could be causing this problem?
  • ThumperKid250F
Posted October 29, 2007 - 10:01 AM
if there is dirt in there, it might of came from when you opened your cap and it fell in...
  • todds924
Posted October 29, 2007 - 10:29 AM
Flush your cooling system and refill with new coolant. Ride the bike then check it again.
If you are running straight water, it's probably a sign that there's been some corrosion of the aluminum in the system.
Drain it and refill with a good corrosion inhibiting coolant.
  • Ga450owner
Posted October 29, 2007 - 10:30 AM
flush it out and keep an eye on it....coolant should not be getting dirty
  • SUnruh
Posted October 29, 2007 - 10:36 AM
it could be a water pump seal or hoses that are disolving. which would be bad too.
i would pull the water pump cover and take a look. a new water pump seal is about $4.
the last thing you want is it going out on a ride. it drains all your coolant out the bottom weep hole and you never know it.
  • todds924
Posted October 29, 2007 - 12:24 PM
It sounds like straight water was put in at some point.
  • nolzey
Posted October 30, 2007 - 03:31 AM
ive been running motul coolant and water wetter and it was not chewing water there for a bit but it is starting to use more water again. i top it up with straight water so thats mabye why its doing it. ill give it a flush and see how it goes. thanks.
  • Hot  30 replies
  • On January 15, 2017
  • Hot  28 replies
