Swimming XR500
4 replies to this topic
  • aswatas
Posted October 26, 2007 - 11:44 PM
We have done an enduro trip and my XR managed to fall into a river, since then we drained the water out and fitted new rings, she starts on the first kick now but immediately starts smoking a lot, the sleeve has been honed as well prior fitting the new rings, why is it smoking now? can it be the head?
Any comments or suggestions would be appreciated..:worthy:
  • scalejockey
Posted October 27, 2007 - 07:31 AM
check the ring end gap you might have too small of rings for the bore . I did this once....I re-ringed a 600 with a worn cylinder. With the "proper"piston sized rings. It smoked like a mother-in-law. So I went to the next size ring set and filed the ends to get the proper end gap. (cheap fix ,I didn't want to bore it) worked great!!!
  • aswatas
Posted October 27, 2007 - 09:59 PM
Hi,
Found the problem, firstly i bought genuine parts rings from Honda and fitted them, it smoked....after re opening it i compared the new oil ring inner ( copper looking wavey thing ) to the old one and the new one looked different.
So what i did is to only replace that oil ring inner with the old and voilla no more smoke.
I cannot believe it worked but this goes to show that the new one that looks different in shape did not stop the oil then :worthy:
Problem fixed.
  • scalejockey
Posted October 28, 2007 - 06:18 AM
ya the inner "spring" is what really makes them work..unless the bore is simply too big. I wonder if someone cut the spring down to make it fit ,then returned them to the dealer?? Or am I just PARANOID???
  • martinfan30
Posted October 29, 2007 - 09:07 PM
Paranoid...lol
  • Hot  60 replies
  • 9 replies
  • 4 replies
  • 3 replies
Honda XR650L 2017
  • 0 reviews
