Compression Lost
I used my bike for the first time in three months (injury lay off) and found there was no compression - I could move the kick start by hand. I had changed the oil and checked the valve clearances, swingarm headset lube etc (one armed maintenance) but not started it. After checking front to back, decomp action, spark plug etc I noted the compression was getting slightly better each kick - clammy valve?
After about seven million kicks it started so I killed it and checked again, compression was back and it ran well, starting first kick.
Any ideas?
? GREMLIN'S mate.......No seriously it could well be a sticky valve, I allways make a point of bringing the bike to TDC when I leave it a long time, mainly so that there is no pressure on the springs, but also so that the chamber is sealed keeping out moisture, short of tearing into the head to check everything, I dont know what to say except keep an eye on it, Unless someone else has a different soluton??? :D
