2005 XR650l PCV remove? smog removal kit
8 replies to this topic
  • HBXR650
Posted October 25, 2007 - 05:24 PM
Just bought the smog block off kit from Xr's Only and the copy for the instructions that came with the parts really suck! I think I got it all done right but I'm confused about where it says to remove the PCV valve. I'm I suppose to remove the entire thing? I still have the large aluminum plug and one of the rubber caps left in the kit. Has anyone done the smog block off kit on a 2005 XR650L that can help?
  • martinfan30
Posted October 25, 2007 - 08:27 PM
ya i have an 05 and the directions do suck. check this out...
http://www.4strokes....?TOPIC_ID=16361
and this...
http://www.4strokes..../honda/xrlsmog/
  • HBXR650
Posted October 28, 2007 - 07:53 AM
Thanks for the links. I knew it was in one of the forums I was reading but didn't save it in my favorites. Now I need to do the carb mods.
  • Cobalt650
Posted October 29, 2007 - 03:49 PM
I just purchased a new 2007 XR650L. What benefits are realized by removing the smog equip?
  • cleonard
Posted October 29, 2007 - 04:02 PM
Don't toss your smog crap. The day may come when it gets checked for and while it would suck to have to install it again, it would suck more to have to buy it again.
I don't own a 650L , but I think that the main impact is weight. It doesn't weigh a lot. It has no performance hit. More or less the same for the charcoal cannister. It might cause some issue in a crash should it fill with gas.
  • martinfan30
Posted October 29, 2007 - 06:47 PM
cleonard is right. the biggest effect is weight and unsightliness. with a small impact on decel "popping" through the exhaust.
  • maverick152
Posted October 29, 2007 - 09:05 PM
Hi, new here. Just got a new '07 650L myself. When you say "impact on decel popping", do you mean less or more? This is my first thumper and I wasn't sure if the decel popping was normal. I'm used to using engine braking on street bikes, but I find myself doing it less on the xr because of the excessive popping. Is there any reason for concern? Thanks, Mahi.
  • martinfan30
Posted October 29, 2007 - 09:11 PM
no reason for concern... unless you want it to run cooler and get rid of the popping.
by removing the smog equip. you will help that prob. slightly. by rejetting with "Daves mods" or a dynojet kit you will ELIMINATE the popping and get more power plus run cooler. all this with a foam air filter and a slip on exhaust pipe will make a complete different machine power wise.
  • Denn10
Posted October 30, 2007 - 09:42 AM
do yourself a favor and just remove it and keep it tucked away, i doubt in the next few years you will have to reinstall it. i got mine and it was all removed and i dont have the parts but im not worried one bit about that.
